RuntimeError: workspace already in transaction mode
1481
11-09-2022 01:52 PM
YinghongLi1
I got  "RuntimeError: workspace already in transaction mode" in the code listed below.  I have been using the similar lines of the code in other scripts and i had never got this problem.
The database is a versioned SDE database (Oracle).  Please help.
Thanks😢😢😢😢
Code:
arcpy.env.workspace = r'in_memory\split'
arcpy.env.addOutputsToMap = False
arcpy.AddMessage("start process")
aprx = arcpy.mp.ArcGISProject("CURRENT")
currentmap = aprx.activeMap
address_layer=None
address_flds=["OBJECTID", "PLACE_ID", "DUF_POLY_ID"]
layer=None
layers = currentmap.listLayers()
for lyr in layers:
    print("layer name=="+lyr.name)
    if ("address_point" in lyr.name.lower()):
       address_layer=lyr
       break
workspace_sde=r"C:\Users\liy\AppData\Roaming\Esri\ArcGISPro\Favorites\[email protected]"
edit = arcpy.da.Editor(workspace_sde)
edit.startEditing(False, True)
edit.startOperation()
#there is an address point selected
with arcpy.da.UpdateCursor(address_layer, address_flds) as ucur:
  print ("before update")
  for urow in ucur:
    print ("inside row looping")
    urow[2]=151802
    ucur.updateRow(urow)
    print("update is done")
edit.stopOperation()
edit.stopEditing(True)
Error message
File "<string>", line 26, in <module>
YinghongLi1
I just realized that the connection file the workspace referred too has to pointed to the editing version.  Even if the editing layers are all versioned the database connection file has to do so too.
YinghongLi1
