Remove prefixes
4073
6
01-08-2024 08:57 AM
2Quiker
I am trying to remove prefixes from a table. I have the following code but it removes more than just street prefix. I my code I have E "space", "E ". I need to be able to strip the prefixes so I can sort, then delete duplicates. How can I remove just the prefixes?
with arcpy.da.UpdateCursor(table1,'STREET') as cursor:
    for row in cursor:
        #print row[0]
        if row[0].startswith("S "):
            #print "Deleting S"
            row [0] = row[0].lstrip('S ')
        elif row[0].startswith("E "):
            #print "Deleting E"
            row [0] = row[0].lstrip('E ')
        elif row[0].startswith("W "):
            #print "Deleting W"
            row [0] = row[0].lstrip('W ')
        elif row[0].startswith("N "):
            #print "Deleting N"
            row [0] = row[0].lstrip('N ')
        cursor.updateRow(row)
del cursor
 After code runs i get.
Before CodeAfter code
E Explorerxplorer
E Expeditionxpedtion
E Exectivexecutive
E Exchangexchange
2 Solutions
MErikReedAugusta
MVP Regular Contributor
lstrip is treating "E " as being ["E", " "] and stripping all instances of those two characters from the left of the string, until it reaches a character other than those two.
Try this:
if (row[0].startswith('E ')
    or row[0].startswith('W ')
    or row[0].startswith('N ')
    or row[0].startswith('S ')
    # print('Deleting Cardinal')
    row[0] = row[0][2:]
    cursor.updateRow(row)  # N.B. if you indent this INSIDE the if statement,
                           # then it won't update any value it doesn't have
                           # to which can be handy if you track edits, since
                           # you didn't technically have anything to change
                           # on the ones without a cardinal direction
### The ones below this are optional, if you have full-word cardinals on your prefixes.
elif (row[0].startswith('East ')
      or row[0].startswith('West ')
    row[0] = row[0][4:]
elif (row[0].startswith('North ')
      or row[0].startswith('South ')
    row[0] = row[0][5:]
Since you're always looking for a 2-character* substring at the beginning, you know if you found it that you only need the remainder of the substring after it.  [2:] tells it to go to index 2 (the character after your space), and then just give you the rest of the string from there.
* The elif statements at line 15 & line 20 look for 4- and 5-character substrings, so the indices at lines 19 & 24 also change—assuming you need them.
EDIT: Unrelated sidenote, it is surprisingly a pain to edit code block statements for typos on this forum.  Apologies to anyone who read it before I caught them.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MErikReedAugusta
I'm too lazy to fix the typos in the codeblock right now, but it just occurred to me that the indices for the full-word ones are wrong, because I forgot to count the space.
Line 19:
    row[0] = row[0][5:]
Line 24:
    row[0] = row[0][6:]
M Reed
MErikReedAugusta
Try this:
    row[0] = row[0][2:]
    row[0] = row[0][4:]
    row[0] = row[0][5:]
M Reed
MErikReedAugusta
Line 19:
    row[0] = row[0][5:]
Line 24:
    row[0] = row[0][6:]
M Reed
2Quiker
Thanks for the reply. I was coming back to my post to add code that worked for me.
try:
    # Update the street names in the table
    with arcpy.da.UpdateCursor(table, "STREET") as cursor:
        for row in cursor:
            street_name = row[0]
            # List of common street prefixes to be removed
            prefixes = ['N ', 'S ', 'E ', 'W ', 'North ', 'South ', 'East ', 'West ']
            # Remove prefixes from the street name
            for prefix in prefixes:
                if street_name.startswith(prefix):
                    row[0] = street_name[len(prefix):].strip()
                    break
Your code did work tho. Again thanks for the reply!
MErikReedAugusta
Efficient!  I like it.
Just for fun, I tried to see if I could condense this further.  Here it is!
with arcpy.da.UpdateCursor(table, 'STREET') as cursor:
    for row in cursor:
        row[0] = min([row[0][len(prefix):] if row[0].startswith(prefix) else row[0] for prefix in prefixes], key=len)
First, a list comprehension creates a list of your street name with every prefix attempted to be removed from it.  Then, it turns out the min() function accepts a key argument.  If you give it the built-in len, it gives you the shortest entry from that list back as a single item.
Since, by definition, every item in our generated list is either the original street name or that street name minus a prefix, the shortest possible will always* be the street name minus any applicable prefix.
*An important caveat here: "N South 5th Street" would return as "South 5th Street", which may or may not be desired.  But then, that's a problem of all of the code in this thread.
Also, just to be cheeky, here it is even more condensed.  I saved a whole 3 lines!  But I haven't tested it.  And  while I think the logic and syntax are all sound, it's the height of absurdity, anyway.  Please don't do this to whoever has to read your code behind you.  😛
    [cursor.updateRow(row) for [min([row[0][len(prefix):] if row[0].startswith(prefix) else row[0] for prefix in ['N ', 'S ', 'E ', 'W ', 'North ', 'South ', 'East ', 'West ']], key=len)] in cursor]
M Reed
JoshuaBixby
MVP Esteemed Contributor
As fun as code golf can be, list comprehensions were proposed and accepted "to create lists" (PEP 202 – List Comprehensions | peps.python.org).  I think many would argue that using a list comprehension to perform a mapping function isn't very Pythonic.
JoshuaBixby
Another approach would be to use regular expressions.  Although regular expressions might be a bit overkill for this specific situation, they are much more flexible to handle more complex situations:
    for row in cursor:
        row[0] = re.sub(r"^((?:N|S|E|W|North|South|East|West) )+", "", row[0])
del cursor
The above will result in "N South 5th Street" becoming "5th Street".  If you don't want double prefixes to be removed, just take the "+" out of the regular expression pattern.
