Using MGRS coords from xls to create Point/Line/Poly Features
3526
5
01-03-2024 11:37 PM
jaschofskiAGS
Hello community,
I'm very new to python and try to rebuild/optimize workflows I've done in Modelbuilder.
My current problem set:
I have an xls containing multiple rows and collum's. one of them is a Coordinate Field, containing MGRS coordinates.
Each row represents either a Point, Line or Polygon (dedicated by a Field called "Type").
For Lines and Polygons, the Coordinate field contains multiple MGRS coordinates, separate by a semicolon.
 Up to now I always separated the sheet manually by point Line and Area and convert the multiple coordinates into multiple rows using power queries in xls and a model in ArcPro to create the features.
What I'm looking for is a pythonic way to create the point features (from here I get it on my own to lines and polygons) from the xls, using the MGRS as CoordString directly and not using the ConvertCoordinate Tool. I thought about the combination of Search- and InsertCursors plus the FromCoordString function because I don't have xy formatted coordinates, but I don't find a starting point.
If anyone has experience in using MGRS(or simmilar cordString) to create features, I would be very thankful for any suggestions!
ArcPro Version is 2.6.1
DavidPike
MVP Notable Contributor
Is there a reason not to use the coordinate conversion tool in python?  You could probably do it using a dictionary to get the cartesian coords (for that UTM zone) of the GZD and 100km grid square in the MGRS string, then add on the X and Y.  If that dictionary doesn't exist somewhere on the internet, then seems like a fair amount of effort for no reason I can understand.
jaschofskiAGS
most likely the reason is, that the xlc sheet contains also cells with up to a few 100 chars and Pagebreaks.
From my experience with the Convert Coordinates Tool it will not translate these cells properly from time to time (at least in ModelBuilder) that's why I was looking for a solution to take The MGRS coord directly to create the point features instead of converting them first, but it seems as if there is no appropriate workaround.
jaschofskiAGS
Or let me formulize my question another way around. Is there a way to convert MGRS coordinates which are stored in a single xls Cell, separated by a semicolon and use this coord list to create a point feature class?
JohannesBierer
Maybe you can use python to split and expand the coordinates in two cells, python example:
https://stackoverflow.com/questions/37600711/pandas-split-column-into-multiple-columns-by-comma
jaschofskiAGS
That helped me with the Multi-coord cells, but still not with cresting points from MGRS coord.
I just wonder if there is nobody worked with MGRS to create points without of using the coordConverter tool
