Re: Dynamic segmentation with respect to a control factor Additional Requirements
19471
56
05-08-2015 08:06 AM
ChukwuemekaEzeiruaku
I was able to figure out the error from earlier, but i have one more request.
If i have other fields in the table i want to also show on the out_table for example see table below:
DataUniqueIDItem IDBegin EndInput Table
Observation1555100001
555100105
555100217
555100345
555100435
Observation2600200103
600200226
600200335
DataUniqueIDBegin EndItem IDOutput Table
Observation1555011001
555131001; 1002
555341001; 1002; 1004
555451001; 1002; 1003; 1004
555571002
Observation2600022001; 2002
600232001; 2002
600352002; 2003
600562003
Is there a way to differentiate between records that are within a certain range(with UniqueID) as shown in the table above, plus have other fields for that range (with same uniqueID) in the output table?
I am really grateful for your help thus far guys, Thanks.
i see, yea there are a few missing data for dates
BlakeTerhune
Is that a data cleanup issue or does the code need to accommodate missing dates?
it's not a clean up issue, the data is expected to have missing data..
It'll be nice to have the code to accommodate for missing dates...
If the dates will be a pain i'll suggest we kill it and make the output table to include just the UniqueID, Begin and End, SegmentItems
BlakeTerhune
I updated the code to accommodate missing dates. Attached is the updated code and copy of the output table. I did brief review of the output and there doesn't seem to be any duplicate segments. The only possible issue I see is that it is creating segments that do not have an ItemID. This is because there is a gap in begin and end values. See UniqueID 1446100 for an example.
Awesome Thanks, but there is no attachment to your reply
BlakeTerhune
You don't see this?
Nope, i can see just the text and not the attachments..
BlakeTerhune
Check out Re: Some users unable to get attachments.
Timothy Hales said:
Make sure you open the discussion up and are not viewing it in your Inbox or Activity Stream.
I can't find any discussion button in the page
