Python list to MultiValue output parameter
3450
04-21-2011 03:13 AM
MarcFasel
Hello, how can I transfer objects of a Python list into a MultiValue output parameter?
The code I've written so far (below) put a complete list of layers objects in one row of the MultiValue output parameter but I'd like that each layer to be defined in one particular row:
listOfClippedOutputLayers = []
listInputFC = allInputFC.split(";")
for inFC in listInputFC:
    (inPath, inFC) = os.path.split(inFC)
    # [...] Clipping
    layer = arcpy.MakeFeatureLayer_management(clippedFC, clippedFCLayer)
    listOfClippedOutputLayers.append(layer)
arcpy.SetParameter(3, listOfClippedOutputLayers)
Does anyone know how to do this "transfer"?
Thanks for your help!
Marc
GaryBushek
Have you figured this out? Im looking to doing the same thing.
thanks
BruceNielsen
Since a multivalue input parameter is a text string delimited by semicolons, I would think the output parameter would be the same. In theory, you should be able to create the appropriate output with the following change to the example code:
arcpy.SetParameter(3, ';'.join(listOfClippedOutputLayers))
MarcFasel
Hi Gary, I finally used another solution as MultiValue is not supported for geoprocessing output parameter. Sorry, maybe Bruce's solution works, I didn't try it.
NobbirAhmed
Esri Alum
Yes, Bruce Nielsen's approach works. Thanks Bruce.
