Rename_management / ListFeatureClasses in SDE database
822
05-22-2012 06:13 AM
KevinYanuk
I am working on running through an SDE database, and renaming a few hundred point feature classes using arcpy.Rename_management().  I use ListFeatureClasses to find the files, and once I hit the ones I want to rename, I use a searchcursor to use a field to rename.
When I get to the part in my script where I use this, the script seems to freeze, and I was wondering if SDE feature classes support this?  I ran it on a file gdb, and everything worked fine ...
import arcpy
from arcpy import env
def updateName():
    arcpy.env.workspace = raw_input("Enter path of database: ")
    for tab in arcpy.ListFeatureClasses("","Point",""):
        desc = arcpy.Describe(tab)
        newName = ""
        if desc.datasetType == 'RasterDataset':
            print "Skipping raster "+tab
        if desc.datasetType == 'FeatureClass':
            print "Searching "+desc.datasetType+": "+tab
            for row in arcpy.SearchCursor(tab):
                newName = "StandID_"+str(row.StandID)+"_Pt"
                print "    Updating "+tab+" to "+newName+"..."
                arcpy.Rename_management(tab, newName)
                break
updateName()
print "\nUpdate complete for "+arcpy.env.workspace+"."
BruceNielsen
If all you're doing is renaming the point featureclasses, you don't need a searchcursor. What is your criteria for determining the new name?
KevinYanuk
Well, the new name is coming from a field within the Feature Class called "StandID" - So, I wouldn't I need one to access that field?
Hence:
It works fine with the test geodatabases I was using, it just hangs up at the Rename_management() when I use it on the SDE.
