Python Label Expression
10566
15
10-01-2013 12:36 PM
BartonGriesenauer
I am trying to create one label expression that has two label options.  The first option will stack the parcel number on top of the lot number and the other option would stack the parcel number on top of deeded acreage.  The [LOTNUMBER] field, [PARCEL] field, are text fields the [DEEDACRES] is a double.  I have no python experience, did not think this expression would be this difficult to come up with.  I would appreciate any help.
def FindLabel ( [PARCEL] , [LOTNUMBER] , [DEEDACRES] 😞
  if long([LOTNUMBER]) >1:
    return "<CLR yellow='255'>" +  [PARCEL] + "</CLR>" + '\n' + [LOTNUMBER]
  else:
    return "<CLR yellow='255'>" +  [PARCEL] + "</CLR>" + '\n' + [DEEDACRES]
MatthewDobson
Or using 'not' ....
def FindLabel ( [PARCEL] , [LOTNUMBER] , [DEEDACRES] ):
  if not [LOTNUMBER]:
    return "<CLR yellow='255'>" + [PARCEL] + "</CLR>\n" + str([DEEDACRES])
  else:
    return "<CLR yellow='255'>" + [PARCEL] + "</CLR>\n" + [LOTNUMBER]
BartonGriesenauer
Thank you very much for your help that did it!
Zeke
Honored Contributor
Siran,
To label numbers divisible by 100, use the modulo operator. In the label expression advanced box, set the parser to Python. Then use a function like below:
def FindLabel(somefield):
    if somefield % 100 == 0: return somefield
if you want to label with a different field based on somefield:
def FindLabel(somefield, anotherfield):
    if somefield % 100 == 0: return anotherfield
SiranErysian
this did not work:
I used 50% since I want to label every 50' contour
tried it without brackets around Contour also but it didn';t work.
Zeke
Honored Contributor
You're not using 50%. You're using modulo 50; the modulo operator is the % sign in Python. It's like regular division, except it gives you the remainder.
Primarily though, you need parentheses around the field name in the first line - def FindLabel([Contour]):
You also need to see whether the expression if [Contour] % 50 == 0: You left the 0 out above.
SiranErysian
Thanks. I re do and be more careful next time....
