Programmatically return Feature Class file size and date modified
27115
30
05-21-2013 06:19 AM
JohnDye
There doesn't appear to be a function in arcpy to return the file size of a feature class or it's date modified timestamp.
Anyone have any idea how to do this? I know there is a property somewhere because you can setup ArcCatalog to display the information. However, I want to see it returned in a Python Script so that I can write a two-way synchronization function.
JamesCrandall
Have you distributed this across your organization?  I can see right away it will fail in a Citrix environment.  Too bad because this type of programmatic access is pretty good to have!
MicahBabinski
Hi James,
No I haven't. I developed this solution as part of some R&D on a redesign of an SDE data loading process we have. We need to detect changes in datasets in a range of formats so we can determine which of them have been updated and need to be loaded to our SDE geodatabases. Our current app was set up by my supervisor in C# ArcObjects. It works well but has a few shortcomings and has proven tricky to maintain over the years.
Out of curiosity, what indicates that it will fail in a Citrix environment?
JamesCrandall
It will fail on your import comtypes statement(s)
MattWilkie2
Hi Micah, thanks for this clear start to finish example of using python arcobjects. I hope you don't mind me taking the liberty of folding it into my (very slowly) growing py-arcobjects module(?)
arcplus/ao.py at master · maphew/arcplus · GitHub
MicahBabinski
Hi Matt,
I don't mind at all. Thanks for the shout-out. Happy scripting!
Micah
MattWilkie2
Great, thanks Micah!
MicahBabinski
Things are slow right now at work so I found an answer to the second part of this question: how to get the file geodatabase table/feature class size. In Snippets.py, underneath the GetModifiedDate function, insert:
def GetFileSize(gdb, tableName, featureDataset):
    # Define a function which will convert bytes to a meaningful unit
    def convert_bytes(bytes):
        bytes = float(bytes)
        if bytes >= 1099511627776:
            terabytes = bytes / 1099511627776
            size = '%.2f TB' % terabytes
        elif bytes >= 1073741824:
            gigabytes = bytes / 1073741824
            size = '%.2f GB' % gigabytes
        elif bytes >= 1048576:
            megabytes = bytes / 1048576
            size = '%.2f MB' % megabytes
        elif bytes >= 1024:
            kilobytes = bytes / 1024
            size = '%.2f KB' % kilobytes
        else:
            size = '%.2 fb' % bytes
        return size
    # Setup
    GetStandaloneModules()
    InitStandalone()
    import comtypes.gen.esriSystem as esriSystem
    import comtypes.gen.esriGeoDatabase as esriGeoDatabase
    import comtypes.gen.esriDataSourcesGDB as esriDataSourcesGDB
    # Open the FGDB
    pWS = Standalone_OpenFileGDB(gdb)
    # Create empty Properties Set
    pPropSet = NewObj(esriSystem.PropertySet, esriSystem.IPropertySet)
    pPropSet.SetProperty("database", gdb)
    # Cast the FGDB as IFeatureWorkspace
    pFW = CType(pWS, esriGeoDatabase.IFeatureWorkspace)
    # Get the info for a stand-alone table
    if featureDataset == "standalone":
        # Open the table
        pTab = pFW.OpenTable(tableName)
        # Cast the table to an IDatasetFileStat object
        pDFS = CType(pTab, esriGeoDatabase.IDatasetFileStat)
        # Return the size
        return convert_bytes(pDFS.StatSize)
    else:
        # Open the feature class
        pTab = pFW.OpenFeatureClass(tableName)
        # Cast the table as a IDatasetFileStat
        # Return the size
It's very similar to the GetModifiedDate function, but uses a different property of the IDatasetFileStat object.
...Really though, this information ought to be accessible via something like
arcpy.Describe().modifiedDate
arcpy.Describe().fileSize
MattWilkie2
very nice, thanks, again! FYI, here's a good thread on producing human readable byte sizes: python - Reusable library to get human readable version of file size? - Stack Overflow
LanceShipman
You may want to request this functionality (arcpy.Describe().modifiedDate, arcpy.Describe().fileSize) on the Esri Ideas site.
MicahBabinski
Hi Lance,
Thanks for mentioning the Esri Idea related to this. I've promoted it and hope others will as well.
