Programmatically return Feature Class file size and date modified
27054
30
05-21-2013 06:19 AM
JohnDye
There doesn't appear to be a function in arcpy to return the file size of a feature class or it's date modified timestamp.
Anyone have any idea how to do this? I know there is a property somewhere because you can setup ArcCatalog to display the information. However, I want to see it returned in a Python Script so that I can write a two-way synchronization function.
JamesCrandall
os.path has both of the methods you want (I have not worked with these myself).
os.path.getmtime
os.path.getsize
http://docs.python.org/2/library/os.path.html
ChrisSnyder
Honored Contributor
Unless its a shapefile, I don't believe there is currently a way to do this with arcpy in v10.1.
A trick though to getting this to work is to make a seperate FGBD for each FC.
This code might give you some ideas on how to get the size:
import glob
def compactAndReportFGDB(fgdbPath):
    oldFgdbSize = 0
    for file in glob.glob(fgdbPath + "\\*"):
        oldFgdbSize = oldFgdbSize + os.path.getsize(file)
    arcpy.Compact_management(fgdbPath)
    newFgdbSize = 0
        newFgdbSize = newFgdbSize + os.path.getsize(file)
    compactPct = str(int((oldFgdbSize - newFgdbSize) / float(oldFgdbSize) * 100))
    return compactPct
JamesCrandall
Good point.  I guess you'd have to implement some kind of your own logging process on the gdb to maintain info on modification dates.  Not sure exactly how you'd work out the size of GDB elements too other than creating individual .shp files or gdb's of each item.  ewww.
JamesCrandall
JohnDye
Thanks James,
I initially thought the same thing but was skeptical since Windows doesn't natively understand the GDB format. Needless to say, this raises an error.
JohnDye
By the looks of this http://gis.stackexchange.com/questions/23914/how-to-get-the-size-of-a-file-geodatabase-feature-class... you could probably get at this info with ArcObects someway.
edit: yup.. http://gis.stackexchange.com/questions/24242/how-to-programmatically-determine-the-size-of-a-feature... ArcObjects will get it done.
Thanks James,
I actually saw this before posting here, but I'm not sure how to leverage ArcObjects from Python, if I can at all.
ChrisSnyder
Honored Contributor
JohnDye
Since it's not currently possible through anything I've seen in Python, I've added it to the ideas site.https://c.na9.visual.force.com/apex/ideaView?id=087E00000004eOq
JohnDye
I've never used ArcObjects via Python but you can: http://gis.stackexchange.com/questions/80/how-do-i-access-arcobjects-from-python
sweet. I'll give it a go. thanks!
