NameError: Global Name 'wuh_oh' is not defined
1689
12-29-2022 11:23 AM
JasonMa
sort_links1.py
import geopandas as gpd
#import arcpy
import mapping_module1 as MM
#from arcpy.display import display
gdf_corr = gpd.read_file('G:/Jason Ma/2021Q1 corridors/Toronto1.shp')
corridor_name = 'Toronto1'
gdf_corridor_sorted = MM.Order_the_Links(corridor_name,gdf_corr)
display(gdf_corridor_sorted)
gdf_corridor_sorted.to_file('G:/Jason Ma/2021Q1 corridors/Toronto1_done.shp')
mapping_module1.py
# -*- coding: utf-8 -*-
Created on Thu Sep 5 09:35:39 2019
@author: SALVAIJ
shp_2018Q3_path = 'N:/HERE_GIS_CANADA/2018Q3/2018Q3 corridors/ALL.shp'
shp_2018Q3_AADT_path = 'N:/HERE_GIS_CANADA/2018Q3/2018Q3 corridors/ALL_AADT.shp'
global wu_oh
attributionstring = 'Data from HERE Technologies. Basemap by OpenStreetMaps.'
zoom_lims = [10000.,
25000.,
50000.,
90000.,
fraction_shift = 0.01
zoom_shift = 0
def calculate_map_extent(gdf_city):
import shapely.ops
bounds = shapely.ops.cascaded_union(gdf_city.geometry).bounds
dx = bounds[2]-bounds[0]
dy = bounds[3]-bounds[1]
#map_extent = max([dx,dy,zoom_lims[0]])
map_extent = max([dx,dy])
return map_extent
def calculate_latitude(gdf_city):
import shapely.ops
bounds = shapely.ops.cascaded_union(gdf_city.to_crs(epsg=4326).geometry).bounds
latitude = (bounds[3]+bounds[1])/2
return latitude
def calculate_zoom(map_extent):
if map_extent <= zoom_lims[0]:
zoom=14
elif zoom_lims[0] < map_extent <= zoom_lims[1]:
zoom=13
elif zoom_lims[1] < map_extent <= zoom_lims[2]:
zoom=12
elif zoom_lims[2] < map_extent <= zoom_lims[3]:
zoom=11
elif zoom_lims[3] < map_extent:
zoom=10
return zoom+zoom_shift
#zoom_lon = np.ceil(np.log2(360 * 2.0 / lon_length))
#zoom_lat = np.ceil(np.log2(360 * 2.0 / lat_length))
#zoom = np.max([zoom_lon, zoom_lat])
def part_roads_corridor(corridor,df_corr,map_extent):
import shapely.geometry, shapely.affinity
offset_scale=map_extent*fraction_shift
start_end = df_corr.sort_values(by='POS_ALONG').iloc[[0,-1],:].reset_index(drop=True)
start_point = start_end.loc[0,'geometry'].centroid
end_point = start_end.loc[1,'geometry'].centroid
d = end_point.distance(start_point)
unit_vec = shapely.geometry.LineString( [(0,0),
((end_point.x-start_point.x)/d,
(end_point.y-start_point.y)/d)])
theta = -90
offset_vec = shapely.affinity.rotate(unit_vec, theta, origin=(0,0))
offset_x,offset_y = list(offset_vec.coords[1])
offset_x*=offset_scale
offset_y*=offset_scale
def translate_row(row):
geometry = row.geometry
translated = shapely.affinity.translate(geometry,xoff=offset_x, yoff=offset_y, zoff=0.0)
return translated
shifted_geometry = df_corr.apply(translate_row,axis=1)
return shifted_geometry
def add_corr_num(ax,gdf_corr,map_extent,corr_num,legend_fontsize):
import matplotlib.patches as mpatches
from numpy import sqrt
offset_scale=map_extent*fraction_shift*4
N = len(gdf_corr)
midway = int(N/2)
mid_start = gdf_corr.sort_values(by='POS_ALONG').iloc[ midway].geometry.centroid
mid_end = gdf_corr.sort_values(by='POS_ALONG').iloc[midway+1].geometry.centroid
mid_start = shapely.geometry.Point(mid_start)
mid_end = shapely.geometry.Point(mid_end)
d = mid_end.distance(mid_start)
unit_vec_x,unit_vec_y = (mid_end.x-mid_start.x)/d, (mid_end.y-mid_start.y)/d
unit_vec = shapely.geometry.LineString( [(0,0),(unit_vec_x,unit_vec_y)])
theta = -90
arrow_base_x,arrow_base_y = mid_start.x+offset_x,mid_start.y+offset_y
arrow_dx,arrow_dy = offset_scale*unit_vec_x,offset_scale*unit_vec_y
r = sqrt(arrow_dx**2 + arrow_dy**2)/2
circle = mpatches.Circle((arrow_base_x,arrow_base_y),
r,
facecolor='white',
edgecolor='black',
linewidth=0.5,
ax.add_artist(circle)
ax.text(arrow_base_x,arrow_base_y,
corr_num,
verticalalignment='center',
horizontalalignment='center',
fontsize=legend_fontsize-1
def add_direction_arrow(ax,gdf_corr,map_extent,corridor):
problem_corridors = ['Toronto1_E',
#'Toronto1_W',
'Toronto3_E',
#'Toronto3_W',
'Toronto4_N',
#'Toronto4_S',
N = len(gdf_corr)
midway = int(N/2)
#mid_start,mid_end = midrows.iloc[0].centroid,midrows.iloc[1].centroid
if any([corridor==problem_corridor for problem_corridor in problem_corridors]):
theta = +90
else:
theta = -90
ax.arrow(arrow_base_x,arrow_base_y, arrow_dx,arrow_dy,
width=offset_scale*.1,
fc='k', ec='k')
def add_basemap(ax_or_axes,
map_extent,
latitude,
zoom='auto',
url='http://a.tile.openstreetmap.org/{z}/{x}/{y}.png',
# another good one is 'http://tile.stamen.com/toner-lite/{z}/{x}/{y}.png'
alpha=1,
aspect='auto',
scalebar=True,
from contextily import bounds2img
if type(ax_or_axes)==list:
ax=ax_or_axes[0]
axes = ax_or_axes
else:
ax=ax_or_axes
xmin, xmax, ymin, ymax = ax.axis()
centre_loc_x,centre_loc_y=(xmax+xmin)/2.,(ymax+ymin)/2.
floored_map_extent = map_extent = max([map_extent,zoom_lims[0]])
if aspect == 'square':
xmin,xmax = centre_loc_x - floored_map_extent/2.,centre_loc_x + floored_map_extent/2.
ymin,ymax = centre_loc_y - floored_map_extent/2.,centre_loc_y + floored_map_extent/2.
elif aspect == 'auto':
pass
else:
print('aspect should be "square" or "auto". Using "auto".')
if zoom=='auto':
zoom = calculate_zoom(floored_map_extent)
else:
pass
basemap, extent = bounds2img(xmin, ymin, xmax, ymax, zoom=zoom, url=url)
for ax in axes:
ax.imshow(basemap, extent=extent, interpolation='bilinear',alpha=alpha)
# restore original x/y limits
ax.axis((xmin, xmax, ymin, ymax))
else:
def add_scalebar(ax,latitude):
from mpl_toolkits.axes_grid1.anchored_artists import AnchoredSizeBar
from numpy import cos,pi
dx= xmax - xmin
ground_meters = dx*cos(latitude*pi/180.)
ground_kms = ground_meters/1000
bar_kms = max([1, ground_kms//7])
bar_length = bar_kms*1000/cos(latitude*pi/180.)
#print(ground_meters,ground_kms,bar_length)
bar_height = 100
bar = AnchoredSizeBar(ax.transData, #transform
bar_length, #Horizontal length of the size bar, given in coordinates of transform.
'%d km'%(bar_kms), #Label to display.
4,#location
pad=0.5,#Padding around the label and size bar, in fraction of the font size. Defaults to 0.1.
sep=5, #Seperation between the label and the size bar, in points. Defaults to 2.
borderpad=0.5,#Border padding, in fraction of the font size. Defaults to 0.1.
frameon=True,#If True, draw a box around the horizontal bar and label. Defaults to True.
size_vertical=bar_length/13,#Vertical length of the size bar, given in coordinates of transform. Defaults to 0.
#color='black',#Defaults to black
#fontproperties=fontprops, #use FontManager
ax.add_artist(bar)
''' Locations:
'upper right' : 1,
'upper left' : 2,
'lower left' : 3,
'lower right' : 4,
'right' : 5,
'center left' : 6,
'center right' : 7,
'lower center' : 8,
'upper center' : 9,
'center' : 10
def add_cbar(vmin,vmax,cmap,fig,ax):
from mpl_toolkits.axes_grid1 import make_axes_locatable
from pylab import cm, Normalize
divider = make_axes_locatable(ax)
cax = divider.append_axes("right", size="5%", pad=0.1)
sm = cm.ScalarMappable(cmap=cmap, norm=Normalize(vmin=vmin, vmax=vmax))
# fake up the array of the scalar mappable. Urgh...
sm._A = []
cbar = fig.colorbar(sm, cax=cax)
return cbar,cax
def other_node_type(node_type):
if node_type == 'REF_IN_ID':
return 'NREF_IN_ID'
elif node_type == 'NREF_IN_ID':
return 'REF_IN_ID'
else:
print ('%s isnt a valid node type'%(node_type))
raise ValueError('argument node_type must be either "REF_IN_ID" or "NREF_IN_ID". Instead receieved %s'%(node_type))
def pop_row(df,index):
#MAKES THE CHANGE TO df IN PLACE AND RETURNS THE REMOVED ROW
out_row = df.loc[index,:]
df_row_removed = df.loc[df.index.difference([index]),:]
return df_row_removed,out_row
def Order_the_Links(corridor_name,corr_df):
import pandas as pd
corridor_direction = corridor_name[-1]
node_types = ['REF_IN_ID', 'NREF_IN_ID']
df_corridor_unsorted = corr_df.copy()
df_corridor_sorted = pd.DataFrame(columns = corr_df.columns.to_list()) #initialize the empty df, to which rows will be added
N_rows = len(df_corridor_unsorted)
#find the NODE IDs that are unique to both rows
#in most cases, there will be 2: a start and an end point
#these may be REF_IN_ID or NREF_IN_ID
#in toronto because of express and collector, there are more than 2. deal with that later
all_nodes = pd.concat([df_corridor_unsorted[node_type] for node_type in node_types],
keys=node_types
).reset_index(level=0).rename(columns={'level_0':'NODE_COL',0:'NODE_ID'})
start_end_nodes = all_nodes.drop_duplicates(subset='NODE_ID',keep=False)
index_coord_A = start_end_nodes.index.values[0]
index_coord_B = start_end_nodes.index.values[1]
coord_A = list(df_corridor_unsorted.loc[index_coord_A,'geometry'].coords)[0]
coord_B = list(df_corridor_unsorted.loc[index_coord_B,'geometry'].coords)[0]
if corridor_direction == 'N':
if coord_A[1]-coord_B[1] > 0:
start_end_iter = 1
else:
start_end_iter = 0
elif corridor_direction == 'E':
if coord_A[0]-coord_B[0] > 0:
start_end_iter = 1
else:
start_end_iter = 0
elif corridor_direction == 'S':
start_end_iter = 0
else:
start_end_iter = 1
elif corridor_direction == 'W':
start_end_iter = 0
else:
start_end_iter = 1
else:
wuh_oh
if len(start_end_nodes) == 2:
unsorted_index = start_end_nodes.index.values[start_end_iter]
node_in_type,node_in_id = start_end_nodes.values[start_end_iter]
last_node_type,last_node_id = start_end_nodes.values[(start_end_iter+1)%2]
for i in range(0,N_rows):
#print(i,len(df_corridor_sorted),len(df_corridor_unsorted))
current_link_endpoints = [list(df_corridor_unsorted.loc[unsorted_index,'geometry'].coords)[ 0],
list(df_corridor_unsorted.loc[unsorted_index,'geometry'].coords)[-1]
#in one line, remove the row from UNSORTED and add it to SORTED
df_corridor_unsorted,df_corridor_sorted.loc[i] = pop_row(df_corridor_unsorted,unsorted_index)
node_out_type = other_node_type(node_in_type)
node_out_id = df_corridor_sorted.loc[i,node_out_type]
if i == N_rows-1:
#end of algorithm
print (corridor_name,last_node_id==node_out_id) #they should match
df_corridor_sorted.index+=1
df_corridor_sorted = df_corridor_sorted.reset_index().rename(columns={'index':'POS_ALONG_CORR'})
return df_corridor_sorted
else:
#update list of nodes
all_remaining_nodes = pd.concat([df_corridor_unsorted[node_type] for node_type in node_types],
keys=node_types
### update variables for next iteration of loop
unsorted_index = all_remaining_nodes[all_remaining_nodes['NODE_ID']==node_out_id].index.values[0]
node_in_type,node_in_id = all_remaining_nodes[all_remaining_nodes['NODE_ID']==node_out_id].values[0]
next_link_endpoints = [list(df_corridor_unsorted.loc[unsorted_index,'geometry'].coords)[ 0],
if df_corridor_sorted.loc[i,'DIR_TRAVEL']=='B':
for j in [0,1]:
for k in [0,1]:
if current_link_endpoints[j]==next_link_endpoints[k]:
diffs = [a-b for (a,b) in zip(current_link_endpoints[j],current_link_endpoints[(j+1)%2])]
if diffs[1] > 0:
dir_travel = 'F'
elif diffs[1] < 0:
dir_travel = 'T'
elif diffs[1] == 0:
if diffs[0] > 0:
dir_travel = 'F'
elif diffs[0] > 0:
dir_travel = 'T'
df_corridor_sorted.loc[i,'DIR_TRAVEL']=dir_travel
df_corridor_sorted.loc[i,'LINK_DIR']='%d%s'%(df_corridor_sorted.loc[i,'LINK_ID'],dir_travel)
else:
print(corridor_name,'unsorted. Found',len(start_end_nodes),"start/end candidates. Should be only 2")
df_corridor_unsorted['POS_ALONG_CORR']=pd.Series([0 for i in range(0,len(df_corridor_unsorted))])
cols = df_corridor_unsorted.columns.tolist()
df_corridor_unsorted = df_corridor_unsorted[[cols[-1],] + cols[0:-1]]
return df_corridor_unsorted
def quick_map_show(gdf,column=None):
import pylab as P
fig=P.figure(figsize=(10,10))
ax=fig.add_subplot(111)
if column:
gdf.plot(ax=ax,
column=column
else:
gdf.plot(ax=ax)
ax.set_axis_off()
return fig,ax
Issue is: The global_name is not found , I try a few times to defined , but don't know where the variable is defined where appropriate , any help from someone can look at this code is much appreciated
AlfredBaldenweck
MVP Frequent Contributor
I can think of three things.
It looks like "wuh_oh" might be supposed to refer to a function that covers error handling, but isn't present. If this is the case, the function has to be defined elsewhere, and it should be
def wuh_oh(params):
 '''code'''
'''code'''
'''code'''
else:
    wuh_oh(params)
If it's supposed to be literally "wuh_oh", just put it in quotes
else:
    "wuh_oh"
But if it's actually supposed to be a variable, then you just have to define it in that function, unless you're planning to use it elsewhere.
var wuh_oh = #something
'''Code'''
JasonMa
Thanks for the reply, Alfred , wu_oh could be defined as variable which I can put as part in ORder_the_links functions
Error :
Runtime error
File "<string>", line 16, in <module>
File "mapping_module1.py", line 370, in Order_the_Links
wuh_oh
NameError: global name 'wuh_oh' is not defined
Global name is supposed to be defined all the way at top of the script Global variable where the function picks up , I was wondering I am debugging this code(from someone) and I not sure how this wuh_oh is defined , I give these a these steps you have previous provided, I get back to you if issues arises
Thanks again
AlfredBaldenweck
I just noticed a typo: the global is defined as "wu_oh", not "wuh_oh". I didn't catch it earlier, sorry.
RhettZufelt
MVP Notable Contributor
Please see code formatting link here.
