Please, stop swizzling Python scripts
5984
10
12-10-2024 01:08 AM
Kepa
by Esri Contributor
Hi everybody,
I am struggling to understand how a script that runs flawlessly in ArcGIS Pro can be flagged as having syntax errors after the publishing process. This inconsistency is both frustrating and highly problematic, as it disrupts workflows and undermines confidence in the publishing system throughout our customers. I believe this situation requires immediate investigation and resolution to ensure a smoother and more reliable user experience.
DougBrowning
MVP Esteemed Contributor
When I talked to someone on the GP team they said if you save to a service definition file then you can see the changed script but I have not tested it yet.
