ModelBuilder how to compare several fields between 2 FCs
4624
7
02-25-2016 03:39 PM
JoseSanchez
Hello everyone,
I need to check if features from one FC match features from another feature class. For this purpose I need to compare 3 fields from the first FC to 3 fields from the second FC.
How can I compare 2 feature classes using more than one field? With one field I can use join a join. Is is possible to join several fields between 2 FCS?
Do I need to do this compare in python or vb.net?
Thanks
XanderBakker
Esri Esteemed Contributor
Probably the easiest way to do this is using Python. You mention ModelBuilder. You can create a tool with Python and add it to ModelBuilder. What do you want to do with the matching features?
XanderBakker
JoseSanchez
I am comparing two different days of the same feature class and I am looking for unmatched features to find records inserted and deleted.
Thanks
XanderBakker
And what should be the output of the tool? A list of differences of a selecting of features?
What if a feature geometry or an attribute that is not being considered in the validation, has been changed?
JoseSanchez
Good questions!
Can you help me with an answer?
XanderBakker
To help you a bit,  have a look at the tool and code below:
Parameters:
  • 0: FeatureLayer (1)
  • 1: Field (multivalue, derived from featurelayer1)
  • 2: Featurelayer (2)
  • 3: String (direction output) additions
  • 4: String (direction output) deletes
What you choose to do with the resulting lists defines how they should be defined and formatted as output.
Result:
Code:
def main():
    import arcpy
    fc1 = arcpy.GetParameterAsText(0)
    selected_flds = arcpy.GetParameterAsText(1)
    fc2 = arcpy.GetParameterAsText(2)
    flds = selected_flds.split(';')
    # check if selected fields in fc2
    arcpy.AddMessage('Check if selected fields in fc2')
    for fld in flds:
        if len(arcpy.ListFields(fc2, fld)) == 0:
            arcpy.AddError('ERROR: Field {0} not in {1}'.format(fld, fc2))
    fld_oid1 = arcpy.Describe(fc1).OIDFieldName
    fld_oid2 = arcpy.Describe(fc2).OIDFieldName
    flds1 = [fld_oid1] + flds
    flds2 = [fld_oid2] + flds
    # validation: are the three fields combined unique?
    arcpy.AddMessage('Validation: are the three fields combined unique?')
    if not isUnique(fc1, flds1):
        arcpy.AddError("The combination of the 3 field for FC1 is not unique")
    if not isUnique(fc2, flds2):
        arcpy.AddError("The combination of the 3 field for FC2 is not unique")
    # create dictionary
    arcpy.AddMessage('Create dictionaries')
    dct1 = generateDict(fc1, flds1)
    dct2 = generateDict(fc2, flds2)
    # create sets
    arcpy.AddMessage('Create sets')
    set1 = set(dct1.keys())
    set2 = set(dct2.keys())
    # check additions (in FC2, but not in FC1)
    arcpy.AddMessage('Check additions (in FC2, but not in FC1)')
    adds = [dct2 for a in list(set2 - set1)]
    if len(adds) > 0:
        arcpy.AddMessage('OIDs added: {0}'.format(adds))
    arcpy.SetParameterAsText(3, adds)
    # check deletes (in FC1, but not in FC2)
    arcpy.AddMessage('Check deletes (in FC1, but not in FC2)')
    dels = [dct1 for a in list(set1 - set2)]
    if len(dels) > 0:
        arcpy.AddMessage('OIDs deleted: {0}'.format(dels))
    arcpy.SetParameterAsText(4, list(dels))
def generateDict(fc, flds):
    return {u'{0}#{1}#{2}'.format(r[1], r[2], r[3]): r[0] for r in arcpy.da.SearchCursor(fc, (flds))}
def isUnique(fc, flds):
    lst1 = [u'{0}#{1}#{2}'.format(r[1], r[2], r[3]) for r in arcpy.da.SearchCursor(fc, (flds))]
    return len(lst1) == len(list(set(lst1)))
if __name__ == '__main__':
    main()
ChrisDonohue__GISP
If Python is not your thing, another possible approach would be to use the Feature Compare tool
Feature Compare—Help | ArcGIS for Desktop
Chris Donohue, GISP
XanderBakker
Very true, with the advantage that it will compare all the fields, BUT if the order of the featureclass is changed, it will not be able to detect the changes correctly.
