In this example, how do I write a Python script to accomplish this?
6282
18
06-27-2018 05:40 AM
CharlesBanks2
In this example, how do I write a Python script to accomplish this result:
Site   ID
SIte A 0001
Site A 0001
SIte A 0001
Site A 0001
Site B 0002
SIte B 0002
Site B 0002
Site C 0003
SIte D 0004
CharlesBanks2
Yes, I did, and got something like this:
FIELDNEED TO BE
xxx_ 9999TUNK10_xxx_ 9999TUNK10_001
xxx_ 9999TUNK10_xxx_ 9999TUNK10_002
xxx_ 9999TUNK10_xxx_ 9999TUNK10_003
xxx_ 9999BANK12_xxx_ 9999BANK12_002
DanPatterson_Retired
# lines 7... change to
        cnt += 0   # ---- try changing this
        ret = "{} {:04.0f}".format(val, cnt)
    else:
        cnt += 1   # ---- and this
        ret = "{} {:04.0f}".format(val, cnt)‍‍‍‍‍‍
CharlesBanks2
I got an error: 999999 : Error executing function.
show your field calculator dialog with the function and your expression filled in
Any of you other peeps want to leap in... lots of viewers... no suggestions from the gallery???  You can take over if you want
RandyBurton
Peeping in.....
A dictionary solution could look like something like this:
data = ['xxx_9999TUNK10_',
        'xxx_9999TUNK10_',
        'xxx_9999TUNK10_',
        'xxx_9999BANK12_',
        'xxx_9999BANK17_',
        'xxx_9999BANK1_',
        'xxx_9999BANK20_',
        'xxx_9999BANK20_',
        'xxx_9999BANK20_',
        'xxx_9999BANK30_' ]
d = {}
cnt = 0
for row in data:
    if row not in d.keys():
        cnt += 1
        d[row] = cnt
        print "{}{:04.0f}".format(row, cnt)
    else:
        print "{}{:04.0f}".format(row, d[row])
Results:
xxx_9999TUNK10_0001
xxx_9999TUNK10_0001
xxx_9999TUNK10_0001
xxx_9999BANK12_0002
xxx_9999BANK17_0003
xxx_9999BANK1_0004
xxx_9999BANK20_0005
xxx_9999BANK20_0005
xxx_9999BANK20_0005
xxx_9999BANK30_0006
Is the prefixed 'xxx_' always the same, or does it vary?  If it varies, you will need to do some string splitting, etc.
Is the postfixed '_' always present?  If not, the formatting statement can be modified to include it.
By making the dictionary 'd' and the counter 'cnt' global, you should be able to make it work for the field calculator.  The code should also work with an update cursor, should you wish to go that route.
CharlesBanks2
Prefix is always the same and suffix is always present and varies. Could I
substitute the data portion with the field name?
Charles Banks
RandyBurton
Not sure I understand your question.  Would something like this do what you want?
        'xxx_9999TUNK10_',
        'xxx_9999TUNK10_',
        'xxx_9999BANK12_',
        'xxx_9999BANK17_',
        'xxx_9999BANK1_',
        'xxx_9999BANK20_',
        'xxx_9999BANK20_',
        'xxx_9999BANK20_',
        'xxx_9999BANK30_' ]
d = {} # empty dictionary
cnt = 0 # counter
def seq_count(fname, val):
    global d
    global cnt
    if val not in d.keys():
        cnt += 1
        d[val] = cnt
        return "{}_{}{:04.0f}".format(fname, val, cnt)
    else:
        return "{}_{}{:04.0f}".format(fname, val, d[val])
fieldName = 'myField'
for item in data:
    print seq_count(fieldName, item)
Results:
myField_xxx_9999TUNK10_0001
myField_xxx_9999BANK12_0002
myField_xxx_9999BANK17_0003
myField_xxx_9999BANK1_0004
myField_xxx_9999BANK20_0005
myField_xxx_9999BANK30_0006
CharlesBanks2
Yes.
Charles Banks
CharlesBanks2
Sorry about the delay. Here it is:
