In this example, how do I write a Python script to accomplish this?
6270
18
06-27-2018 05:40 AM
CharlesBanks2
In this example, how do I write a Python script to accomplish this result:
Site   ID
SIte A 0001
Site A 0001
SIte A 0001
Site A 0001
Site B 0002
SIte B 0002
Site B 0002
Site C 0003
SIte D 0004
DanPatterson_Retired
I am suspecting that there is more to it than that.
  • What is the purpose of the code?
  • Do any of the values exist before hand?
  • are you reading the file from somewhere?
  • What have you tried!
CharlesBanks2
This is in connection with post: "Sequential Numbering Python Script for
Field Calculator in Arc 10.2" but a different sequence in the data.
Charles Banks
Well it can be done easily in more recent versions ( Table tools for ArcGIS PRO )
but perhaps if you included the link someone with an older version of ArcMap (or even 10.6) could have a look at what was posted there
CharlesBanks2
The link is "
https://community.esri.com/thread/192672-sequential-numbering-python-script-for-field-calculator-in-...".
I don't have Pro and I would have to do this from Field Calc.
Charles
The code I posted is in that link... you just need to change the field name that contains the source classification
seq_count(!Test!)
in that thread's example the Site stuff was in a field called Test.
You just need to do a field calculation with seq_count as the Code block and the seq_count(!YourFieldName!) as the expression.
Of course, you have to set the field calculator to the python parser
CharlesBanks2
This script does not produce the sequence above, it does work though!
It doesn't produce the exact sequence because... your data are different I suspect.
Perhaps you should show the data you are trying to produce a sequence for... or are you not following what the script does exactly?
CharlesBanks2
This is a sample of what needs to be:
FIELDNEED TO BE
xxx_ 9999TUNK10_xxx_ 9999TUNK10_001
xxx_ 9999BANK12_xxx_ 9999BANK12_002
xxx_ 9999BANK17_xxx_ 9999BANK17_003
xxx_ 9999BANK1_xxx_ 9999BANK1_004
xxx_ 9999BANK20_xxx_ 9999BANK20_005
xxx_ 9999BANK30_xxx_ 9999BANK30_006
did you substitute the !Test! name in the field calculator expression and try what I suggested?
perhaps you can take a screen grab of the field calculator dialog so we can see what you are doing
