If-then-else
7131
16
01-07-2016 11:11 AM
CCWeedcontrol
I need help setting up an if-than-else within a if-else statement. I need the code i need to check if selected features has any text inside the AddressID field if it does have any text inside the field i need it to by pass the with arcpy.da.SearchCursor and the with arcpy.da.UpdateCursor and move on to the next process. if doesn't have any text inside the field i need it to preform the with arcpy.da.SearchCursor and the with arcpy.da.UpdateCursor. I would appreciate any help.
  1. import arcpy, os
  2. from arcpy import env
  3. env.workspace = r"C:\temp\python\test.gdb"
  4.
  5. arcpy.env.qualifiedFieldNames = False
  6. arcpy.env.overwriteOutput = True
  7.
  8. BldSelection = "BuildingFootprints"
  9. Bld = arcpy.env.workspace + os.sep + "BuildingFootprints" #target point feature class
  10.
  11. BldCount = int(arcpy.GetCount_management(Bld).getOutput(0))
  12.
  13. dsc = arcpy.Describe(BldSelection)
  14. selection_set = dsc.FIDSet
  15. if len(selection_set) == 0:
  16.     print "There are no features selected"
  17.
  18. elif BldCount >= 1:
  19.     #Gets the highest AddressID and calculates new point to assign new highest AddressID
  20.     Bld_list = []
  21.     with arcpy.da.SearchCursor(Bld, ["Bld_ID"]) as cursor:
  22.         for row in cursor:
  23.             try:
  24.                 if "Bld" in row[0]:
  25.
  26.                     Bld_list.append(int(row[0].strip("Bld")))
  27.             except TypeError:
  28.                 pass
  29.     del cursor
  30.
  31.     print Bld_list
  32.
  33.     Bld_list.sort()
  34.     Bld_ID = Bld_list[-1] + 1
  35.
  36.
  37.     with arcpy.da.UpdateCursor(BldSelection, "Bld_ID") as rows:
  38.         for row in rows:
  39.             row[0] = 'Bld' + str(Bld_ID)
  40.             Bld_ID += 1
  41.             rows.updateRow(row)
  42.         del row
  43.         del rows
WesMiller
Why not use Make Feature Layer—Help | ArcGIS for Desktop  and remove those that have data before you start your cursor.
MakeFeatureLayer_management (in_features, out_layer, "Field" > '')
CCWeedcontrol
I am not sure i follow, add MakeFeatureLayer_management (in_features, out_layer, "Field" > '') in between lines 20 & 21?
WesMiller
Something similar to below
import arcpy, os
bldlyr = arcpy.MakeFeatureLayer_management(Bld,"Building_layer","AddressID > ''")
BldCount = int(arcpy.GetCount_management(bldlyr).getOutput(0))
elif BldCount >= 1:
    Bld_list = []
    with arcpy.da.SearchCursor(bldlyr, ["Bld_ID"]) as cursor:
        for row in cursor:
            try:
                if "Bld" in row[0]:
            except TypeError:
                pass
    del cursor
    print Bld_list
    Bld_list.sort()
        for row in rows:
            Bld_ID += 1
            rows.updateRow(row)
        del row
        del rows
CCWeedcontrol
Wes suggestion is interesting, i never thought of doing that. I made the change to the code but the Bld_ID for the selected feature doesn't get populated.
I will still like to see how to use the if-ten-else
import arcpy, os
arcpy.env.workspace = r"Database Servers\DSD15_SQLEXPRESS.gds\CCAPTEST (VERSION:dbo.DEFAULT)"
BldSelection = "CCAPTEST.DBO.BldTaxChar"
Bld = arcpy.env.workspace + os.sep + "CCAPTEST.DBO.BldTaxChar" #target point feature class
elif BldCount >= 1:
    # Start an edit session. Must provide the worksapce.
    edit = arcpy.da.Editor(arcpy.env.workspace)
    # Edit session is started without an undo/redo stack for versioned data
    #  (for second argument, use False for unversioned data)
    edit.startEditing(True)
    # Start an edit operation
    edit.startOperation()
    Bld_list = []
        for row in cursor:
            try:
                if "Bld" in row[0]:
            except TypeError:
                pass
    del cursor
    print Bld_list
    Bld_list.sort()
        for row in rows:
            row[0] = 'Bld%05d' %Bld_ID
            Bld_ID += 1
            rows.updateRow(row)
        del row
        del rows
    # Stop the edit operation.
    edit.stopOperation()
    # Stop the edit session and save the changes
    #edit.stopEditing(True)
    if arcpy.Exists(parcel_lyr): arcpy.Delete_management(parcel_lyr)
    arcpy.RefreshActiveView()
WesMiller
See below
condition = 1
if condition == 1:
    print 'yes it is'
else:
    print "no it isn't"
Edit
This may be a better example for what you are trying to do.
import arcpy
fc = 'Your feature class'
field = 'your field'
with arcpy.da.SearchCursor(fc, [field]) as cursor:
    for row in cursor:
        if row[0] >'':
            print row[0]
        else:
            print 'update row'
CCWeedcontrol
ok, for some reason i was thinking i had to put an if-then-else statement after "elif BldCount >= 1: " line 21
after making the following adjustment, the selected features "Bld_ID" field still doesn't populate when i run the following code...? I get no error.
Edit:
I had things that i need to change. the code is now working, i think. i will do testing.
Thanks Wes!
import arcpy, os
elif BldCount >= 1:
    with arcpy.da.SearchCursor(BldSelection , "Bld_ID") as cursor:
        for row in cursor:
            if row[0] >'':
                Bld_list = []
                    for row in cursor:
                        try:
                            if "Bld" in row[0]:
                        except TypeError:
                            pass
                del cursor
                print Bld_list
                Bld_list.sort()
                    for row in rows:
                        Bld_ID += 1
                        rows.updateRow(row)
                    del row
                    del rows
            else: #other process sptial join
    #if arcpy.Exists(parcel_lyr): arcpy.Delete_management(parcel_lyr)
CCWeedcontrol
spoke to soon the code is not working, no errors, field Bld_ID doesn't get populated
CCWeedcontrol
I just noticed that some of the selected features are "NULL", would that affect line 36?
WesMiller
Null < ''
