If-then-else
7114
16
01-07-2016 11:11 AM
CCWeedcontrol
I need help setting up an if-than-else within a if-else statement. I need the code i need to check if selected features has any text inside the AddressID field if it does have any text inside the field i need it to by pass the with arcpy.da.SearchCursor and the with arcpy.da.UpdateCursor and move on to the next process. if doesn't have any text inside the field i need it to preform the with arcpy.da.SearchCursor and the with arcpy.da.UpdateCursor. I would appreciate any help.
  1. import arcpy, os
  2. from arcpy import env
  3. env.workspace = r"C:\temp\python\test.gdb"
  4.
  5. arcpy.env.qualifiedFieldNames = False
  6. arcpy.env.overwriteOutput = True
  7.
  8. BldSelection = "BuildingFootprints"
  9. Bld = arcpy.env.workspace + os.sep + "BuildingFootprints" #target point feature class
  10.
  11. BldCount = int(arcpy.GetCount_management(Bld).getOutput(0))
  12.
  13. dsc = arcpy.Describe(BldSelection)
  14. selection_set = dsc.FIDSet
  15. if len(selection_set) == 0:
  16.     print "There are no features selected"
  17.
  18. elif BldCount >= 1:
  19.     #Gets the highest AddressID and calculates new point to assign new highest AddressID
  20.     Bld_list = []
  21.     with arcpy.da.SearchCursor(Bld, ["Bld_ID"]) as cursor:
  22.         for row in cursor:
  23.             try:
  24.                 if "Bld" in row[0]:
  25.
  26.                     Bld_list.append(int(row[0].strip("Bld")))
  27.             except TypeError:
  28.                 pass
  29.     del cursor
  30.
  31.     print Bld_list
  32.
  33.     Bld_list.sort()
  34.     Bld_ID = Bld_list[-1] + 1
  35.
  36.
  37.     with arcpy.da.UpdateCursor(BldSelection, "Bld_ID") as rows:
  38.         for row in rows:
  39.             row[0] = 'Bld' + str(Bld_ID)
  40.             Bld_ID += 1
  41.             rows.updateRow(row)
  42.         del row
  43.         del rows
CCWeedcontrol
I have tried the following for blank and null attributes for line 36, but i am getting error.  Parsing error SyntaxError: invalid syntax
with arcpy.da.SearchCursor(BldSelection , "Bld_ID") as cursor:
        for row in cursor:
            if row[0] > '' or row[0] Null <":
and
        for row in cursor:
            if row[0] > '' :
               if row[0] Null <":
I have tried, but nothing happends, the Bld_ID of the selected feature doesn't update.
        for row in cursor:
            if row[0] > None or row[0] == ' ':
DanPatterson_Retired
You need to learn something about nothing...
nothing = None, "", {}, []
obj = None  # or "" '' [] et
if not obj:
    print("something here")
else:
    print("nothing object")
CCWeedcontrol
I have tried the following but nothing happens, no error
obj = None, "", ' '
        for row in cursor:
            if not obj:
                    Bld_list = []
                        for row in cursor:
                            try:
                                if "Bld" in row[0]:
                            except TypeError:
                                pass
                    del cursor
                     print Bld_list
                    Bld_list.sort()
                        for row in rows:
                            row[0] = 'Bld%05d' %Bld_ID
                            Bld_ID += 1
                            rows.updateRow(row)
                        del row
                        del rows
            else: #other process sptial join
                # Stop the edit operation.
                edit.stopOperation()
Ok... clearly
obj  is an object... any object ... pick one
  • it will either have a null state, such as empty strings ( '', ""), lists dictionaries  or sets ( [], {} () ) or...
  • it will be null, like None, np.Nan etc etc
if obj
  • means if the object is something or has a non-null values or state.... do something in the lines that immediately follow
  • conclusion?  if the value is something then do something with it
if not obj:
  • if the object is null, then do something.  this condition is used to do "stuff" when objects are null
Confused?????  Never check the code you are trying to get working to see if the logic works... you will just keep spinning your cerebral wheels.  always check the logic you are working on, using something that you know works.
CCWeedcontrol
Dan I uderstad what you and Wes are saying with the explanations/logic I am just not sure how to put it into the current code to reflect what I am trying to accomplish.
I have lost sight of...or not fully grasped... the need for the code in the first place.  This appears to be a solution to a one-off or seldom performed task.  I advise breaking it into parts that you can solve even if it means that you will have to perform several individual steps rather than one automagic solution.
WesMiller
In support of what Dan is saying it appears to be a simple select by attribute followed by a field calculate. The whole process shouldn't take more than a minute.
