How to move a layer to a group?
2039
05-12-2024 02:08 PM
HKN
Hi, I am trying to move a layer to a group using python. Both the layer and the group are in the current/same map.
I have the following code (the layer to be moved to the group "VMS" is "Fishnet_v1_manual")
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
mp = aprx.listMaps()[0]
lyr_to_move = mp.listLayers("Fishnet_v1_manual")
group_layer = mp.listLayers("VMS")
mp.addLayerToGroup(group_layer, lyr_to_move, "AUTO_ARRANGE")
But I keep getting this error:
ValueError                                Traceback (most recent call last)
In  [37]:
Line 8:     mp.addLayerToGroup(group_layer, lyr_to_move, "AUTO_ARRANGE")
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\utils.py, in fn_:
Line 191:   return fn(*args, **kw)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\_mp.py, in addLayerToGroup:
Line 3559:  return convertArcObjectToPythonObject(self._arc_object.addLayerToGroup(*gp_fixargs((target_group_layer, add_layer_or_layerfile, add_position), True)))
ValueError: []
I have also tried moving the layer to after the first layer in the group using moveLayer, but still get a similar error message as the above. The code I used for this is:
import arcpy
lyr_to_move = mp.listLayers("Fishnet_v1_FeatureLayer_v3")
ref_layer = mp.listLayers(r"Data points in grid")
mp.moveLayer(ref_layer, lyr_to_move, "AFTER")
The error message is:
In  [38]:
Line 9:     mp.moveLayer(ref_layer, lyr_to_move, "AFTER")
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\_mp.py, in moveLayer:
Line 3772:  return convertArcObjectToPythonObject(self._arc_object.moveLayer(*gp_fixargs((reference_layer, move_layer, insert_position), True)))
ValueError: []
Any ideas on how to fix this error or are there other ways of moving a layer to a group in the current map? Thanks for your help and ideas.
Clubdebambos
MVP Regular Contributor
Hi @HKN
listLayers always returns a list. When using the wildcard with a layer name or group layer name you are more than likely returning a list that contains one layer so you need to put [0] at the end like below.
lyr_to_move = mp.listLayers("Fishnet_v1_manual")[0]
group_layer = mp.listLayers("VMS")[0]
~ learn.finaldraftmapping.com
Clubdebambos
Hi @HKN
HKN
Hi @Clubdebambos , thanks for the above. It works fine now with this change.
