How to get point position in layout?
2126
11-02-2020 12:48 PM
anyry
Hello,
I have layer of points and I need know their position in layout (in milimetres) from map frame. How can i do that please?
Thanks
Tags (1)
DavidPike
MVP Notable Contributor
The DataFrame Class will have the origin of the data frame in page units, but the location of points in the layer aren't referenced in any classes that I know of (my lack of knowledge on this is not an indication of very much).
You may have better luck by converting your points to graphics then using the arcpy.mapping GraphicElement.elementPositionX, GraphicElement.elementPositionX  class (or Pro equivalent).
I would also do physical trials to see if print margins etc. are included.
anyry
Thanks but I think that in Pro is not possible convert features to graphics.
DavidPike
I had a think about this.
You coukd get the origin coordinates of the extent of your dataframe, then take the shape x,y xoordinates of each point and minus the dataframe origin coordinate values.
the dataframe also has a scale attribute value which you can then divide by to get the paper distance(x,y) of each point from the dataframe.
then add these values to the x,y position of the dataframe.
simples!
anyry
That's great idea! thank you so much, David.
