How to copy fc datasets and define projection
2022
01-26-2019 01:20 PM
KimCollins
Hello,
    I am new to the world of python. I have a geodatabase with feature datasets and multiple types of feature classes within those datasets. I'm trying to write a script that will search through the specified geodatabase and copy items into new datasets within a new geodatabase. I also need to define a projection for the data as it goes into the new gdb.
I've been doing it manually in ArcCatalog by creating a new dataset in the target gdb and defining a projection, then importing the feature classes into it. However this has been pretty time consuming.
This is what I have so far for my script, I think I may be completely lost and I'm not sure if .da.Walk is what I should be using
gdbFrom = arcpy.GetParameterAsText(0)
gdbTo = arcpy.GetParameterAsText(1)
Projection = arcpy.GetParameterAsText(2)
for datasets in arcpy.da.Walk(gdbFrom):
     for fc in datasets:
LanceCole
I typically use the following for crawling through unknown database feature datasets and feature classes:
arcpy.env.workspace = gdbFrom
for ds in arcpy.ListDatasets(feature_type='feature')
   do what you need with each feature dataset
   for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
      do what you need here for each feature class in a dataset
To define a spacial reference for a dataset:
cs = arcpy.SpatialReference(4326)   # for GCS_WGS_1984 as an example
arcpy.DefineProjection_management(dataset, cs)
If you are not modifying the data just applying a coodinate system and/or transformation to the dataset you could use Project—Help | ArcGIS for Desktop on each feature dataset setting your gbdFrom and gbdTo, in and out coordinate system and transformation if needed.  Do not forget about applying a transformation if need or your data may end up in the wrong part of the world.
arcpy.Project_management(gdbFrom/in_dataset, gbdTo/out_dataset, cs)
ListDatasets—Help | ArcGIS Desktop
ListFeatureClasses—ArcPy Functions | ArcGIS Desktop
SpatialReference—Help | ArcGIS Desktop
Define Projection—Help | ArcGIS Desktop
LanceCole
