How to simply add a layer for a GPFeatureRecordSetLayer parameter
805
01-28-2019 07:40 AM
JohannesLindner
I want to have an interactive Input layer for a tool in a python Toolbox. I'm only interested in the geometry the user specified, other attributes don't matter.
This is what I have now:
    def getParameterInfo(self):
        p1 = arcpy.Parameter(name = "point", displayName = "bla", datatype = "GPFeatureRecordSetLayer", parameterType = "Required", direction = "Input")
        # get target layer from MapDocument and create a temporary copy
        mxd = arcpy.mapping.MapDocument("CURRENT")
        layer = arcpy.mapping.ListLayers(mxd, "layer_name")
        temp_path = "Path:\\to\\layer.lyr"
        layer.saveACopy(temp_path)
        # assign the layer to p1
        p1.value = temp_path
        return [p1]‍‍‍‍‍‍‍‍‍
That works, but it's very cumbersome (it's slow, there has to be a layer with the geometry I want in the map, I can't hardcode the layer path, because I can't be sure the user has write permissions (and I can't save it to in_memory), and I would have to delete the layer to avoid cluttering random directories).
Is it possible to create a point (or line or whatever) layer file on the fly? Or can I somehow save a layer with the python modules and reference it in the script?
Have a great day!
Johannes
