How do you get the SetProgressor() to actually display?
5971
9
01-23-2012 08:13 AM
JeremyRead
I have tried running my Python script in both PythonWin and a regular window, and it doesn't show up either way.
arcpy.SetProgressor("step", "Processing...")
do stuff...
arcpy.SetProgressorPosition(3)
Do I actually have to "print" it somehow?
curtvprice
In a stand-alone script, your script isn't being called from an ArcGIS application, so there is no progress dialog box, result, or Python window where your messages can be viewed.
Arc 10 Help: Writing messages in script tools
JeremyRead
Ah, gotcha.  Thanks!
The example in Desktop Help for SetProgressor() didn't really mention anything about that.  I appreciate the link for help with messages 🙂
JeremyRead
OK, well... I spoke too soon.  I looked at the help that you linked and I still don't really get it.  I still don't see how to tell it to display the step progressor each time it updates (steps).
curtvprice
The help I linked is about printing messages -- which is what you have to do in scripts not run as a toolbox's script tool.
The help for SetProgressor has a code sample at the bottom on how to update progressor messages and the progressor "bar graphic".
I've found that sometimes progressor messages from tools you are running (especially spatial analyst tools) trump your progressor settings. In those cases the progressor doesn't always do exactly what you want.
BlakeTerhune
Have you found any way to override or supress these other progressor messages from Esri?
curtvprice
No. But, this is a little bit moot as the progressors are not out front anymore (ArcMap background processing, Pro).
JeremyRead
I must have an issue on my machine or something.  My script is setup to work just like the example.  I even copied/pasted the example and ran it on my own machine (double-clicked the script icon) and it worked, but I saw nothing.
LoganPugh
SetProgressor only takes effect when you run the script as a script tool from within an ArcGIS application (ArcMap, ArcCatalog, etc.). Running it standalone or from a Python IDE/interpreter, it will not display the progress dialog.
JeremyRead
Ok, thank you.  I guess I will need to find a different method.
