GetParameter() - Double Value needs to be re-cast as a Double (from string)
604
9
12-11-2025 09:37 AM
MGAL
In my tool, I have one parameter that accepts a double value. In my script, I have to re-cast the value as a float() type.
proximity_threshold = float(arcpy.GetParameterAsText(1))
 This feels kind of silly to have to re-cast the value that was originally input as the correct data type.
Is there a more elegant solution here that I'm not seeing?
AlfredBaldenweck
MVP Regular Contributor
Yeah just use arcpy.GetParameter()
MGAL
That's what I thought too...
When I change the line to...
proximity_threshold = arcpy.GetParameter(1)
arcpy.AddMessage(proximity_threshold)
arcpy.AddMessage(type(proximity_threshold))
if near_dist < proximity_threshold:
TypeError: '<' not supported between instances of 'float' and 'str'
Messages before the failure show 10, and <class 'str'> respectively. Here's my tool parameter config for good measure.
-M
DavidSolari
Alfred's suggestion is the intended way to get a Double parameter so I can't say why it's failing for you. As a workaround, try getting all your parameters using arcpy.GetParameterInfo() and then use the value or valueAsText parameters as needed. For example, a drop-in replacement for the first line of your sample is:
proximity_threshold = arcpy.GetParameterInfo()[1].value
MGAL
That worked...
I'm still not understanding why the double data type is so buried in the tool. For example, I also have a boolean parameter in this tool, and the ".GetParameter()" method works w/o transformation.
In my mind, the toolboxes parameters should dictate the data type of the incoming data as it was configured in the toolbox. Otherwise, what's the point of setting a data type?
DanPatterson
MVP Esteemed Contributor
It is one reason that I use the old school sys.argv
Accessing parameters in a script tool—ArcGIS Pro | Documentation
you just have to remember that sys.argv[0] is the script and sys.argv[1] is parameter id 0
... sort of retired...
AlfredBaldenweck
Dumb question, but what's the parameter type of near_dist?
MGAL
near_dist isn't a parameter... it's derived from the script. it's the variable for the output of .distanceTo() the geometry method (outputs double).
the script joins information from two different line feature classes, to a table of inspection points. where the tables' ID's don't match 1:1 (for reasons i don't want to get into :/) the script reverts to a proximity match. the proximity match is the min threshold that automatically matches the line to the point.
def find_closest_line(pcs_geom, input_fc, oid_idx, shape_idx, proximity_threshold):
    near_dists = {}
    for feats in input_fc:
        for k,v in feats.items():
            oid = v[oid_idx]
            shape = v[shape_idx]
        near_dist = pcs_geom.distanceTo(shape)
            # arcpy.AddMessage("Bullseye!")
            return list(feats.values())[0]
        else:
            near_dists[oid] = near_dist
    if len(near_dists) == 0:
        return False
    closest_oid = sorted(near_dists.items(), key=lambda item: item[1])[0][0]
    closest_feat = [oid for rows in input_fc for oid in rows.keys() if oid == closest_oid]
            if v[oid_idx] == closest_oid:
                return v
    return closest_feat
(note that "input_fc" is really a list of python dictionaries derived from SearchCursor)
depending on the size & location quality of the incoming dataset, this value can be adjusted to speed up the process, or slow down the process to get better accuracy. the tool also has a boolean parameter that puts the process into a test mode to allow the user to see the results as a formatted arcpy message, before the data is appended to the master inspection table.
not a dumb question!
AlfredBaldenweck
So, I tested this just now on 3.5.5 and I don't have any problem?
Script documentation
- Tool parameters are accessed using arcpy.GetParameter() or
                                     arcpy.GetParameterAsText()
- Update derived parameter values using arcpy.SetParameter() or
                                        arcpy.SetParameterAsText()
import arcpy
def script_tool(param0):
    """Script code goes below"""
    x = float(10)
    y = param0+x
    arcpy.AddMessage(y)
    return
if __name__ == "__main__":
    param0 = arcpy.GetParameter(0)
    script_tool(param0)
I'd double-check the types of everything again. You can arcpy.AddMessage(type(x)) to make sure.
If everything is actually as intended, this is super weird and would probably worth trying to replicate in an unrelated toolbox with a very simple tool (as above).
DanPatterson
you can float both with issue in python
(float(1) == float("1")) and (float("1.0") == float(1.0))
True
so if it isn't an integer, float/double or text, what is it?
