Cannot run MakeFeatureLayer for geodatabase featureclass
826
12-11-2025 12:50 PM
Kevin_Andras
Hi, I can't figure out why this won't run.  Any of the methods below return ERROR 000732.  I just created the geodatabase, and it's the latest version.  ListFeatureClasses() will show the layer, but then arcpy.management.MakeFeatureLayer() fails.
There are some other geodatabases on my computer that will work, but I don't know why this one won't.   I can export the feature class to a shapefile and then arcpy.management.MakeFeatureLayer will work on that.
#this is a geodatabase feature class. I can view it in ArcGIS, and within Arc I can run MakeFeatureLayer.
input_hydro = "F:\\scratch4\\test.gdb\\hydroTest"
arcpy.env.workspace = os.path.dirname(input_hydro)
ds = arcpy.ListFeatureClasses()
for d in ds:
       print(d) #prints HydroTest
input_hydro_FL = arcpy.management.MakeFeatureLayer(in_features=input_hydro, out_layer="hydroOriginal")
input_hydro_FL = arcpy.management.MakeFeatureLayer(in_features=d, out_layer="hydroOriginal")
input_hydro_FL = arcpy.management.MakeFeatureLayer(in_features=os.path.basename(input_hydro, out_layer="hydroOriginal")
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset hydroTest does not exist or is not supported
Failed to execute (MakeFeatureLayer).
DanPatterson
MVP Esteemed Contributor
don't you want the workspace set to the gdb? not the folder that it is in?
 arcpy.env.workspace = "C:/data/base.gdb"
not the c:/data folder as an example
... sort of retired...
Kevin_Andras
os.path.dirname(input_hydro) returns the path to the GDB.    When I set that as the workspace, it fails. When I give the full path to the in_features, it also fails. It works fine with some other geodatabases, and also works fine with shapefiles.
TonyAlmeida
MVP Regular Contributor
I would double check to make sure that feature class exists and there is no extra characters in the name.
Do a simple print out of all the features in the database,
import arcpy
# Set workspace to the geodatabase
gdb_path = r"F:\scratch4\test.gdb"
arcpy.env.workspace = gdb_path
# List all feature classes
feature_classes = arcpy.ListFeatureClasses()
print(f"Geodatabase: {gdb_path}")
print(f"Feature class count: {len(feature_classes)}")
print("=" * 70)
if feature_classes:
    print(f"{'No.':<4} {'Name':<30} {'Alias Name':<30}")
    print("-" * 70)
    for i, fc in enumerate(feature_classes, 1):
        try:
            # Get the full path to describe
            fc_path = f"{gdb_path}\\{fc}" if not "\\" in fc else fc
            desc = arcpy.Describe(fc_path)
            alias_name = desc.aliasName if hasattr(desc, 'aliasName') else "(no alias)"
            print(f"{i:<4} {fc:<30} {alias_name:<30}")
        except Exception as e:
            print(f"{i:<4} {fc:<30} ERROR: {str(e)[:30]}")
else:
    print("No feature classes found.")
