Export raster attribute table into CSV using Python automation !
12683
17
11-25-2013 05:25 PM
YamMagar
Hello,
I am learning python scripting. I am trying to export raster attribute table (integer value) in to .CSV file. I can manually export attribute table into .txt file but would take many hours to export for 100 raster files. I have raster files (about 100) organized in a folder called "temperature". So, how can I write a python script that scan through all raster files and export attribute table of each raster into .CSV file with unique header file.
Thanks.
JohnWani
@Xander Bakker , the code runs fine for me and also generates .csv files but they contain only headers.
I am attaching a copy of *.csv files generated and some sample files.
Please help
Regards
John
XanderBakker
Esri Esteemed Contributor
I changed the code to this and that resulted in csv files with data.
import arcpy, os
ws = r'D:\Xander\GeoNet\Raster2CSV\data'
outPath = r'D:\Xander\GeoNet\Raster2CSV\csv'
outExt = ".csv"
arcpy.env.workspace = ws
rasters = arcpy.ListRasters("*")
for raster in rasters:
    rasloc = os.path.join(ws, raster)
    fields = '*'
    try:
        flds = arcpy.ListFields(rasloc)
        header = ','.join([fld.name for fld in flds])
        if len(flds) != 0:
            outCSV = os.path.join(outPath, '{0}{1}'.format(raster, outExt))
            with open(outCSV,'w') as f:
                header += ',RasterName\n'
                f.write(header)
                curs = arcpy.SearchCursor(rasloc)
                for row in curs:
                    lst = [row.getValue(fld.name) for fld in flds]
                    lst.append(raster)
                    line = ','.join(str(a) for a in lst)
                    f.write(line + '\n')
    except Exception as e:
        print "Error processing", raster
        print "Error", e
        print "Is raster not integer or is there no attribute table?"
del row, curs‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
See files attached.
BlakeTerhune
MVP Frequent Contributor
Is there an advantage to using the csv module over just creating a file with .csv extension and writing lines to it like you did in this example? Your way seems much simpler.
DanPatterson_Retired
the csv module handles way more cases and error checks to its toolset.  If you have a well know data structure and you will be using it, then simple is good, should there be a chance that others may be doing it perhaps with poorly formed data, then the csv module is worth a look, just to save writing error checking.
GugaDB
Hello! First of all, sorry to revive an old post.
I'm also new to GIS, and needed something similar to this post, but I'm getting only one row of data from my rasters attribute tables.
The script which I'm replying to is creating the CSV files, generating two from four headers (creates objectid and rastername, but not "value" and "count", which are other columns from my attribute table) and writes just the first line of data from my rasters. I attached one example.
Also, it would be better for me to all this data got into one file, is that possible?
Could someone help?
Thanks!
GugaDB
by Anonymous User
Not applicable
Looking at the docs for the search cursor, it says that raster fields are not supported:
"Raster fields are not supported."
What does your code look like?  ... It would probably be best to create a new topic for your question.
JohnWani
xander_bakker‌, Thanks a lot for the code, it worked perfectly.
Thanks again for saving my time.
Regards
John
