Export layers of a gdb as excel table
10343
22
02-16-2021 05:06 PM
JoelRodriguez95
Hello everybody,
I'm new in this world of arcpy and I would like poder export all of layer of a gbd to an excel format, I tried with several this foro's scripts but I can't get the result, this is my script actual but not funcionate.
import arcpy
from arcpy import env
env.workspace = r" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final.gdb"
output_folder = of = r" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final\Excel"
for fc in arcpy.ListFeatureClasses("*"):
        fc_name= of+ "\\"+fc+".xls"
        print(fc_name)
        arcpy.TableToExcel_conversion(fc,fc_name, "NAME", "CODE")
JoelRodriguez95
Thanks for yout time! I tried with this script but I get the following error:
Parsing error SyntaxError: invalid syntax (line 10)
by Anonymous User
Not applicable
ok could a difference between python 2 and 3. Change it to:
out_xls = os.path.join(output_folder, r'{}.xls'.format(fc))
JoelRodriguez95
sorry for the inconvenience :(, but it throws me error:
>>> import os
... import arcpy
... from arcpy import env
... env.workspace = r" C:\Users\LAP77\JR\Veg_Hidro_Final\Veg_Hidro_Final.gdb"
... output_folder = r" C:\Users\LAP77\JR\Veg_Hidro_Final\Excel"
... for fc in arcpy.ListFeatureClasses("*"):
...     print(fc)
...     out_xls = os.path.join(output_folder, r'{}.xls'.format(fc))
...     print(out_xls)
...     fc_table_view = arcpy.MakeTableView_management(fc,"tview")
...     arcpy.TableToExcel_conversion(fc_table_view, out_xls)
 C:\Users\LAP77\JR\Veg_Hidro_Final\Excel\Veg_Hidro_Final.xls
Runtime error  Traceback (most recent call last):   File "<string>", line 12, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 6966, in MakeTableView     raise e ExecuteError: ERROR 000732: Input Table: Dataset Veg_Hidro_Final does not exist or is not supported
these are the feature classes in the gdb:
and this a part of table's Veg_Hidro_Final
by Anonymous User
Not applicable
Try with the full path to the fc:
print(out_xls)
fc_path = os.path.join(env.workspace, fc)
fc_table_view = arcpy.MakeTableView_management(fc_path, "tview")
JoelRodriguez95
nothing 😞
>>> import os
... import arcpy
...     print("1::",fc)
...     print("2::",out_xls)
...     print("3::",fc, out_xls)
...     fc_path = os.path.join(env.workspace, fc)
...     fc_table_view = arcpy.MakeTableView_management(fc_path, "tview")
('1::', u'Veg_Hidro_Final')
('2::', ' C:\\Users\\LAP77\\JR\\Veg_Hidro_Final\\Excel\\Veg_Hidro_Final.xls')
('3::', u'Veg_Hidro_Final', ' C:\\Users\\LAP77\\JR\\Veg_Hidro_Final\\Excel\\Veg_Hidro_Final.xls')
Runtime error  Traceback (most recent call last):   File "<string>", line 15, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\conversion.py", line 81, in TableToExcel     raise e ExecuteError:  Traceback (most recent call last):   File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Scripts\TableToExcel.py", line 222, in <module>     arcpy.GetParameter(3))   File "c:\program files (x86)\arcgis\desktop10.3\ArcToolbox\Scripts\TableToExcel.py", line 216, in table_to_excel     workbook.save(output)   File "C:\Python27\ArcGIS10.3\lib\site-packages\xlwt\Workbook.py", line 662, in save     doc.save(filename, self.get_biff_data())   File "C:\Python27\ArcGIS10.3\lib\site-packages\xlwt\CompoundDoc.py", line 261, in save     f = open(file_name_or_filelike_obj, 'w+b') IOError: [Errno 22] invalid mode ('w+b') or filename: u' C:\\Users\\LAP77\\JR\\Veg_Hidro_Final\\Excel\\Veg_Hidro_Final.xls'  Failed to execute (TableToExcel).
and when I use the script again, this is the error.
Runtime error  Traceback (most recent call last):   File "<string>", line 14, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 6966, in MakeTableView     raise e ExecuteError: ERROR 000725: Table Name: Dataset tview already exists.
by Anonymous User
Not applicable
Ok, Like Dan said earlier you have spaces in your paths. r" C:...".
This error is saying it cant find <space>C:/... in your output.  remove the spaces and try again.
by Anonymous User
Not applicable
for the already exists error, you can del it at the end of the iteration or you can add
env.overwriteOutput = True
under the imports so it overwrites the outputs.
JoelRodriguez95
it was finally achieved! the scripts is this:
import os
import arcpy
env.workspace = r"C:\data.gdb"
output_folder = r"C:\output"
DanPatterson
MVP Esteemed Contributor
print the featureclass name and the out_xls name ... ie print(fc, out_xls)
... sort of retired...
JoelRodriguez95
I did it in my last answer, thanks for your time
