Dissolve/merge features without creating new feature class python
14807
20
01-09-2020 08:35 AM
2Quiker
I have a feature class that can have many features within it i would like to merge all the features in this feature class into just one based on the "BUFF_DIST" like you would in ArcMap when you start editing, select all the features and go to edit, merge and you get the popup "Chose the feature with which other features will be merged:" i am trying to avoid creating a new feature class. Anyone done this or have an example of some python code?
2Quiker
Correct this is would not be a result of buffering, i don't wan to recreate a new feature class and I want to merge the attributes similar to the what you do in Arcmap when you select features,start editing, click editor tool bar- merge. This would all take place in ArcMap's Python not stand alone. I came close to this with the code i posted but i can't get it correct.
Thanks for the reply.
DanPatterson_Retired
The data access editor provides some limited capabilities, but It isn't clear whether geometry changes are fully supported
Editor—Data Access module | ArcGIS Desktop
JamesCrandall
Since you want to overwrite the features that were included in the dissolve/union, you will always have the potential of data loss should something go wrong.  If it were me I'd look to convert the searchCursor to JSON (there's a SHAPE@JSON property available), run the dissolve on that to create a new output, remove the original features then use the JSON of dissolved features to update the original feature class.
You'd have to look into the Reading geometries—ArcPy Get Started | ArcGIS Desktop  and Writing geometries—ArcPy Get Started | ArcGIS Desktop to get full context.  Plus you'd need to come up with the union process -- I just use the GeometryServer/union task on one of our ArcGIS Servers to perform that process on input features like so,
def runUnion(geomEntity):
    queryURL = "https://YourArcGISServerSite/rest/services/Utilities/Geometry/GeometryServer/union"
    params = urllib.urlencode({'f': 'json',
                               'geometries': geomEntity,
                               'geometryType': 'esriGeometryPolygon',
                               'sr': 3857
    req = urllib2.Request(queryURL, params)
    response = urllib2.urlopen(req)
    jsonResult = json.load(response)
    return jsonResult
I think in the end someone mentioned it will take a bit of coding and question if it's worth the effort, which is always the case I guess.  For me, I've simply made the switch from localized data to working 100% with REST services which took a lot of effort to get migrate all of our python implementations off of SDE/FGDB/Local data.  However, in the end it's worth it for us because it opens up the amount of data available to a global scale.
2Quiker
At this point i would like to just merge the features without the attributes.
XanderBakker
Esri Esteemed Contributor
Hi 2 Quiker ,
See the example below:
def main():
    import arcpy
    fc = r'C:\GeoNet\DissolvePy\data.gdb\pols_test'
    fld_dissolve = 'Class'
    # get unique values from field
    unique_vals = list(set([r[0] for r in arcpy.da.SearchCursor(fc, (fld_dissolve))]))
    for unique_val in unique_vals:
        geoms = [r[0] for r in arcpy.da.SearchCursor(fc, ('SHAPE@', fld_dissolve)) if r[1] == unique_val]
        if len(geoms) > 1:
            diss_geom = DissolveGeoms(geoms)
            # update the first feature with new geometry and delete the others
            where = "{} = '{}'".format(fld_dissolve, unique_val)
            cnt = 0
            with arcpy.da.UpdateCursor(fc, ('SHAPE@'), where) as curs:
                for row in curs:
                    cnt += 1
                    if cnt == 1:
                        row[0] = diss_geom
                        curs.updateRow(row)
                    else:
                        curs.deleteRow()
def DissolveGeoms(geoms):
    sr = geoms[0].spatialReference
    arr = arcpy.Array()
    for geom in geoms:
        for part in geom:
            arr.add(part)
    diss_geom = arcpy.Polygon(arr, sr)
    return diss_geom
if __name__ == '__main__':
    main()
A couple of thing to keep in mind:
  • Try this on a copy of your data!
  • It will only works on polygons in this case
  • It assumes that your field to dissolve on is a text field
  • check the where clause to have it match the syntax of your workspace
  • It will put the dissolved polygon in the first of the features for each list of features to dissolve, so any additional fields will have the first value. No intelligence is applied to mimic any merge rules of the fields
Input polygons for testing:
resulting polygons:
2Quiker
Xander,
Thanks for the reply and code, after running your example i noticed that the result is the same as my script. I thought i posted pics of my code results but i guess i didn't. It seems as both your and my code cuts out the over lapping polygons. I forgot to mention that there are some over lapping poygons.
XanderBakker
Hi 2CQuiker ,
Can you change the function "DissolveGeoms" for this one below and try again (on a copy of your data)?:
    cnt = 0
    for geom in geoms:
        cnt += 1
        if cnt == 1:
            diss_geom = geom
        else:
            diss_geom = diss_geom.union(geom)
    return diss_geom‍‍‍‍‍‍‍‍‍
2Quiker
Xander that worked thank you for sharing!
JoshuaBixby
MVP Esteemed Contributor
Here is some code I have used in the past, similar but a bit different to Xander's.  My code does two passes through the data set with the same cursor, the first pass gets the union-ed geometries, and the second pass updates and deletes rows.
from arcpy import da
from itertools import groupby
from operator import itemgetter
from functools import reduce
fc = # path to feature class or table
case_fields = ["field1", "field2"] # field(s) to group records for merging
sort_field, sort_order = "OBJECTID", "ASC"
shape_field = "SHAPE@"
fields = case_fields + [sort_field, shape_field]
sql_orderby = "ORDER BY {}, {} {}".format(", ".join(case_fields), sort_field, sort_order)
with da.UpdateCursor(fc, fields, sql_clause=(None, sql_orderby)) as cur:
    case_func = itemgetter(*range(len(case_fields)))
    merged_polys = {
        key:reduce(arcpy.Geometry.union, (row[-1] for row in group))
        for key, group
        in groupby(cur, case_func)
    cur.reset()
    for key, group in groupby(cur, case_func):
        row = next(group)
        cur.updateRow(row[:-1] + [merged_polys[key]])
        for row in group:
            cur.deleteRow()
If the data set is extremely large, where building a dict of merged polygons might not be practical, there is another approach using an update and search cursor in parallel.
kwargs = {"in_table":fc, "field_names":fields, "sql_clause":(None, sql_orderby)}
with da.UpdateCursor(**kwargs) as ucur, da.SearchCursor(**kwargs) as scur:
    ugroupby, sgroupby = groupby(ucur, case_func), groupby(scur, case_func)
    for (ukey,ugroup),(skey,sgroup) in zip(ugroupby,sgroupby):
        poly = reduce(arcpy.Geometry.union, (row[-1] for row in sgroup))
        row = next(ugroup)
        ucur.updateRow(row[:-1] + [poly])
        for row in ugroup:
            ucur.deleteRow()
2Quiker
I am getting an error and " The field BUFF_DIST is a double, file is a shapefile.
Runtime error
  File "<string>", line 24, in <module>
  File "<string>", line 22, in <dictcomp>
RuntimeError: A column was specified that does not exist
Never mind I forgot to change OBJECTID to FID, since it's a shapefile.
Everything works, thanks for sharing.
