Date value showing in milliseconds
1278
03-13-2024 12:54 AM
Manager_HMWSSBCDC
When I replaced query with objectid = 1 or anything, I'm getting the result but with recvddate column of Date data type I'm the getting the error that is in above pic.
When I run the script with objectid = 1, i had seen the column value of recvddate is in milliseconds format
like
'recvddate': 1672511463000
My actual requirement is I want to filter all the records that are greater than some time value and delete those records.
DanPatterson
MVP Esteemed Contributor
in a file geodatabase?
SQL reference for query expressions used in ArcGIS—ArcGIS Pro | Documentation
 Here is an example of a query that will return all records on or after January 1, 2011, for a date-time field from a file geodatabase data source:
INCIDENT_DATE >= timestamp '2011-01-01 00:00:00'
 When a time that is not null is stored with the dates (for instance, January 12, 1999, 04:00:00), querying the date only will not return the record. When you pass only a date to a date-time field, it fills the time with zeros and retrieves only the records in which the time is 12:00:00 a.m.
... sort of retired...
Manager_HMWSSBCDC
Not in file geodatabase. I want to run this on feature layer which is published in ArcGIS Portal and accessing the data through ArcGIS API for Python.
