Cursor Performance against Layer Selections
966
08-16-2024 09:49 AM
tcrammond
I've been passing the results of selections against layers directly to the arcpy.da.UpdateCursor, and noticed that the performance is terrible. I love the convenience of not deriving some whacky SQL to tell the cursor exactly what I want to update...but at this point, the juice ain't worth the squeeze.
Any tips on making this work? The process is usually something like
selected_stuff = arcpy.GetParameter('selection')  # feature layer input with a selection applied
metrics = {id: metric for id, metric in results}  # parse through some table of results to get the stuff I wan to update
with arcpy.da.UpdateCursor(
        selected_stuff,
        field_names=['id', 'metric'],
) as i_cursor:
    for row in i_cursor:
        metric = metrics.get(row[0])
        if metric and metric != row[1]:
            row[1] = metric
            i_cursor.updateRow(row)
AlfredBaldenweck
MVP Frequent Contributor
I haven't run into this issue myself, but you could try something like:
actualFC = selected_stuff.dataSource
selSet = selected_stuff.getSelectionSet() # get set of OIDs of selected feature
sql = f"OBJECTID IN ({', '.join([str(i) for i in selSet])})"
metrics = {id: metric for id, metric in results}  # parse through some table of results to get the stuff I want to update
        actualFC,
        where_clause = sql
) as i_cursor:
            row[1] = metric
Basically, run the cursor on the actual table based on what you have selected, rather than on the layer.
AlfredBaldenweck
        actualFC,
        where_clause = sql
) as i_cursor:
            row[1] = metric
