Script fails to create Vector Tile Package based on Portal environment
1396
07-18-2024 01:59 PM
Brian_McLeer
MVP Regular Contributor
I am working on a script that will create a Vector Tile Package from ArcGIS Pro and publish to Portal. In my testing portal environment, it functions as expected. When I switch the Portal URL, ItemIDs, etc to my production Portal, I get the below error.
ERROR - Error updating item PortalItemID: ('Failed to create Vector Tile Package MapName: Item with this filename already exists. [itemId=PortalItemID]\n(Error Code: 409)', None)
Does anyone have any suggestions on what might cause this behavior to exist in one instance of Portal but not another? The environment is ArcGIS Enterprise 11.2.
HaydenWelch
Does arcpy.Exists return true when you run out on the output item path? It seems like you either already have an item with that name on your production server or you are creating it twice in your script. Given that your development server test worked I think it's probably the former.
You could test this by running an Exists check and just appending a '_new' to the file name. That way it will say least complete and show you something.
TonyAlmeida
Maybe some debugging and handle the 409 error when publishing a Vector Tile Package
untested.
import arcgis
from arcgis.gis import GIS
from arcgis.gis import Item
import os
# Connect to your GIS
portal_url = "https://yourproductionportalurl.com/portal"
username = "yourusername"
password = "yourpassword"
gis = GIS(portal_url, username, password)
# Define variables
vector_tile_package_path = "path_to_your_vector_tile_package.vtpk"
item_title = "Your Vector Tile Package Title"
item_description = "Description of your vector tile package"
tags = "tag1, tag2, tag3"
# Check if an item with the same title already exists
def check_existing_items(title):
    existing_items = gis.content.search(query=title, item_type="Vector Tile Package")
    for item in existing_items:
        if item.title == title:
            return item
    return None
# Function to publish the vector tile package
def publish_vector_tile_package():
    try:
        # Check for existing items with the same title
        existing_item = check_existing_items(item_title)
        if existing_item:
            print(f"Item with the title '{item_title}' already exists. Deleting the existing item.")
            existing_item.delete()
        # Upload and publish the vector tile package
        print("Uploading the vector tile package...")
        item_properties = {
            "title": item_title,
            "type": "Vector Tile Package",
            "description": item_description,
            "tags": tags
        item = gis.content.add(item_properties, data=vector_tile_package_path)
        print(f"Publishing the vector tile package '{item_title}'...")
        item.publish()
        print("Vector Tile Package published successfully.")
    except arcgis.exceptions.ArcGISException as e:
        if "409" in str(e):
            print(f"Error 409: Conflict. {e}")
        else:
            print(f"An error occurred: {e}")
# Run the function to publish the vector tile package
Brian_McLeer
@TonyAlmeida @HaydenWelch , apologies for the delayed response, I was not getting notifications on this post for some reason. It turned out the issue was that the Vector Tile Package could not overwrite the older file with the same name if it was in the same folder. I created a support ticket with Esri, and we discovered that if I moved the original VTPK to a folder, and then had the script import the newer VTPK with the same file name to the parent folder, it did not cause the issue.
