Create Definition Query
2381
05-21-2021 12:22 PM
jaykapalczynski
Honored Contributor
I am trying to figure out how to create a Definition query and run some code against those records
How do I create the Definition Query from the species name passed to this function?
Points = r"E:/xxxx/ArcGIS/Projects/UserFrontEnd/[email protected]/TestLocations"
def unique_values(table, field):
    species = field
    expressionValue = "common_name = '{}'".format(species)
    # CREATE DEFINTION QUERY FOR COMMON_NAME
        Points Feature Class EQUAL TO the ExpressionValue
    # RUN SOME CODE AGAINST THE RESULTING RECORDS FROM THE DEFINITION QUERY
        Grab the resulting Point records and do something
jaykapalczynski
Honored Contributor
OK I posted my solution on another post...
I think you all for your thoughts....it got me through this one....
I used a Select instead and then used those results to update the polygon with counts
https://community.esri.com/t5/arcgis-api-for-javascript/count-points-in-polygon-and-symbolize-on-num...
DavidPike
MVP Notable Contributor
definition queries work on layers.  What's with the function with a table parameter? Am confused on the detail of this tbh.
BlakeTerhune
It's related to some preprocessing work they are trying to do for a JS app.
Count Points in Polygon and symbolize on number of... - Esri Community
BlakeTerhune
@jaykapalczynski I mentioned before that using Dissolve seems like it would get you the output you want. Have you tried that?
jaykapalczynski
Honored Contributor
Thanks, I will look at the dissolve...
I just do not see where I apply the Polygon Feature Class and the Point Feature Class
jaykapalczynski
Honored Contributor
