Calculating point based and start point, distance and angle
3312
11-08-2022 05:25 AM
TomGeo
I have a point, and based on this point, a certain distance and a bearing I want to calculate the resulting coordinates. And I was wondering how to do this in arcpy, while the spatial reference system is honored.
Lets say I am in EPSG 3006, have an arbitrary point (57.6222951N,18.8333582E), a distance of 2000 meter, and a bearing of 345 degree...
How can I achieve that with arcpy?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
JohannesLindner
For that, you have to use PointGeometry
# what you have
coordinates = (57.6222951, 18.8333582)
sr = 4326
# what you want
bearing = 345
distance = 2000
target_sr = 3006
# create a point geometry from the given coordinates and project it into the target coordinate system
y, x = coordinates
p = arcpy.PointGeometry(arcpy.Point(x, y), arcpy.SpatialReference(sr))
p_proj = p.projectAs(arcpy.SpatialReference(target_sr))
# get the target point geometry
p_target = p_proj.pointFromAngleAndDistance(bearing, distance)
# print coordinates
p_target.firstPoint
#<Point (728268.6981234621, 6395030.819025804, #, #)>
Have a great day!
Johannes
JohannesLindner
# what you have
sr = 4326
# what you want
bearing = 345
distance = 2000
target_sr = 3006
y, x = coordinates
# print coordinates
p_target.firstPoint
Have a great day!
Johannes
