arcpy.da.SearchCursor TypeError: 'field_names' must be string....
484
06-07-2024 06:21 PM
ElisseDeleissegues1
New Contributor III
This is a portion of an inherited code, we have recently upgraded to a more current Enterprise.
The code worked on the older Enterprise version, he rest of the code has been updated and seems to be running fine when run as individual cells.
The Error message:
In  [12]:
Line 13:    with arcpy.da.SearchCursor(fc, fields, query) as row:
TypeError: 'field_names' must be string or non empty sequence of strings
The code:
#Extract Tax Parcels from Parcel Editing (Feature Service on Portal)
source = r"UPDATEDENTERPRISE/HOSTED//FEATURELAYER/FeatureServer/0"
fc = r"UPDATEDENTERPRISE/HOSTED//FEATURELAYER/FeatureServer/0"
CSVFile = r"S:\LOCALSERVERPATH\GISDATA.csv"
query = """("Name" NOT LIKE BLAHBLAHBLAH)"""
fields = [f.name for f in arcpy.ListFields(fc) if f.name in ('Name')]
with open(CSVFile, 'w') as f:
    f.write(','.join(fields)+'\n') #csv headers
        for row in rows:
            f.write(','.join([str(r) for r in row])+'\n')
print("CSV File Created for GIS")
 I've been looking through StackExchange, StackOverflow, Esri Community, etc. for a couple of days now and have tried variations on suggestions but continue to get the same error.
Any suggestions will be very welcome. I am new to this.
Thank you
DavidSolari
Occasional Contributor III
That snippet is an error prone and roundabout way of doing:
field_name = "Name"
query = f"""("{field_name}" NOT LIKE BLAHBLAHBLAH)"""
    f.write(field_name + '\n') #csv header
    with arcpy.da.SearchCursor(fc, field_name, query) as rows:
        for value, in rows:  # Deconstruct the single-item tuple into a single variable using the for loop
            f.write(value + '\n')
This makes the intent clearer and you'll get a more obvious error if the dataset lacks a "Name" field.
AlfredBaldenweck
MVP Regular Contributor
So, field_names required either one field or a list with a length greater than 0.
You appear to be feeding it a list, so the next question is: does that list have anything in it?
It’s possible that your fields don’t match the if statement on line 8. I’d check that out.
BlakeTerhune
On line 8 where you're creating the fields list, the last part where it's checking if f.name in ('Name') seems weird. Are you intending to only make a list with exactly one value of 'Name'? As-is, I think like 8 is actually only getting fields that are "N", "a", "m", "e". If you are wanting to check equality, use an equals:
fields = [f.name for f in arcpy.ListFields(fc) if f.name = 'Name']
If you are wanting to check equality on a number of possible matches, then that tuple needs a comma after the first item:
fields = [f.name for f in arcpy.ListFields(fc) if f.name in ('Name',)]
 Or just use a list instead of a tuple:
fields = [f.name for f in arcpy.ListFields(fc) if f.name in ['Name']]
DavidSolari
field_name = "Name"
ElisseDeleissegues1
New Contributor III
@AlfredBaldenweck @BlakeTerhune @DavidSolari
Thank you all so much for your input!
I went with David's solution as it is simplified from the original and makes more sense to my inexperienced eye.
In addition, the exported portal layer resulted in the Field Name being in all lower case so "Name" was not recognized. I received and error that asked if I meant "name" so I checked, and sure enough that was that problem.
