addLayer error
1996
08-29-2023 11:32 AM
AnjeliDubey
I am trying to add a layer to my current map with this script using a script tool, however whenever I run the script tool it says addLayer failed.
What in my script can be fixed to get addLayer to work?
# import the library needed to add layer
import arcpy
arcpy.env.overwriteOutput = True
# access current project
aprx = arcpy.mp.ArcGISProject('CURRENT')
# access current map
m = aprx.activeMap
try:
    # Create parameter for layer file you want to add
    lf = arcpy.GetParameterAsText(0)
    # Add layer to active map
    m.addLayer(lf)
    #Add message if  layer added
    arcpy.AddMessage("Layer added Successfully!")
except Exception as e:
    arcpy.AddError(f"Error occured: {str(e)}")
AlfredBaldenweck
MVP Frequent Contributor
Add layer takes a layer object and you appear to be feeding it a file path.
Create a layer ( should be arcpy.mp.Layer(), I think) then feed that into addlayer() instead
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/layer-class.htm
AlfredBaldenweck
AnjeliDubey
That worked, thank you!
