Access SDE from Data Store in python toolbox
1415
06-09-2024 10:26 AM
sbrowneotogo
I have a toolbox that accesses a database through an SDE, which is stored locally. This works for local jobs, but I need to deploy this to an Enterprise portal. I've created a Data Store for the SDE, but I can't figure out how to now access the Data Store version of the SDE in a python toolbox. I can find the Data Store through gis.content.search(query='*',item_type="Data Store"). But how do I use it to access a GDB in the SDE?
I need to convert something like:
r'E:\ProProjects\my_project\SDE_connections\my_sde.sde\my_gdb'
To access the same SDE through the Data Store
TonyAlmeida
MVP Regular Contributor
Maybe with ArcGIS API? Untested.
import arcpy
from arcgis.gis import GIS
import os
def main():
    # Get parameters
    portal_url = arcpy.GetParameterAsText(0)
    username = arcpy.GetParameterAsText(1)
    password = arcpy.GetParameterAsText(2)
    data_store_title = arcpy.GetParameterAsText(3)
    # Authenticate with the Enterprise portal
    gis = GIS(portal_url, username, password)
    # Search for the Data Store item
    data_store_items = gis.content.search(query='*', item_type="Data Store")
    # Find the specific Data Store by title
    data_store = next((item for item in data_store_items if item.title == data_store_title), None)
    if data_store is None:
        arcpy.AddError(f"Data Store with title '{data_store_title}' not found.")
        return
    # Get the connection properties
    connection_properties = data_store.properties.connectionString
    # Use arcpy to access the geodatabase
    arcpy.env.workspace = connection_properties
    # Example: List all feature classes in the geodatabase
    feature_classes = arcpy.ListFeatureClasses()
    arcpy.AddMessage(f"Feature Classes: {feature_classes}")
if __name__ == "__main__":
    main()
sbrowneotogo
Thanks for the suggestion. I'm able to get the connection string but it looks like assigning it to the environment causes it to break (the ListFeatureClasses runs forever until I interrupt it)
