Python Ideas
Python Ideas
Other Boards in This Place
This widget could not be displayed.
Latest Activity (77 Idea Submissions)
Sort/Filter :
Open
A new feture was recently added to ArcGIS Pro so that when a python toolbox is refreshed it will popup with the Warni...
GISDepartmentMFM
by GISDepartmentMFM Regular Contributor
in Python Ideas Last Updated 2 weeks ago
6 1
6
Open
Related: How to Determine if the item in geodatabase is a view or not? Related Idea: Catalog: Add view iconThere is n...
AlfredBaldenweck
by AlfredBaldenweck MVP Regular Contributor MVP Regular Contributor
in Python Ideas Last Updated 05-21-2025
4 1
Open
grpc is a widely used rpc framework: It enables an important architectural pattern to consume microservices similarly...
PatrickLuchsinger
by PatrickLuchsinger Emerging Contributor
in Python Ideas Last Updated 03-25-2025
4 1
Open
Issue DescriptionI have been working on re-writing a lot of the utils module in arcpy, as the code in there is an abs...
HaydenWelch
by HaydenWelch MVP Regular Contributor MVP Regular Contributor
in Python Ideas Last Updated 02-23-2025
2 0
Needs Clarification
As you can see, there are a number of requests package extensions that ship with arcpy.I have to often deal with clie...
EricEagle
by EricEagle Frequent Contributor
in Python Ideas Last Updated 05-20-2025
4 3
Open
This is basically a drop in replacement for some really inscrutable code in the utils module that's used to translate...
HaydenWelch
in Python Ideas Last Updated 01-17-2025
0 0
Implemented
Greetings,Since Jupyter Notebooks (and Jupyter Lab) and integral to ArcGIS Pro please include a code formatter for ip...
TylerT
by TylerT Frequent Contributor
in Python Ideas Last Updated 05-16-2025
1 2
Open
https://pro.arcgis.com/en/pro-app/latest/arcpy/geoprocessing_and_python/parameter-controls.htmIt would be helpful if ...
HildermesJoséMedeirosFilho
by HildermesJoséMedeirosFilho Occasional Contributor
in Python Ideas Last Updated 01-13-2025
4 2
Closed
ProblemGlobalID fields in ArcGIS are robust but too long for compact reports, fieldwork, or external systems requirin...
lal-sabbagh
by lal-sabbagh Occasional Contributor
in Python Ideas Last Updated 01-27-2025
3 1
Implemented
Pro 3.1This may be a duplicate of another Idea but I can't find it.A while back I had a project whose data I had to s...
AlfredBaldenweck
in Python Ideas Last Updated 01-08-2025
2 4
Open
I have encountered several circumstances where I was wishing I was able to run arcade expressions directly in a pytho...
ckeener217
by ckeener217 Emerging Contributor
in Python Ideas Last Updated 11-25-2024
2 0
Under Consideration
Given two arcpy.Polyline geometries.If they only touch each other:poly1.touches(poly2) == Trueif poly2 touches and at...
EugeneSosnin_GSI
by EugeneSosnin_GSI Emerging Contributor
in Python Ideas Last Updated 01-09-2025
1 14
Open
When creating tools, I often have different behavior in execution, based on what is essentially a toggle: If the valu...
AlfredBaldenweck
in Python Ideas Last Updated Wednesday
3 5
Open
I would like to be able to add informational notes at the top of custom tools, either with Python or the Toolbox GUI,...
Clubdebambos
by Clubdebambos MVP Regular Contributor MVP Regular Contributor
in Python Ideas Last Updated 01-03-2025
4 2
Needs Clarification
ESRI should really offer a way to control numeric format (thousand separator, number of decimal, etc.) for DOUBLE, FL...
AntoinePrince1805
by AntoinePrince1805 Occasional Contributor
in Python Ideas Last Updated 12-16-2024
2 1
218 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
