OIC 360 Images Not showing the whole 360 view
293
05-27-2024 05:47 AM
HabtamneshGoite
New Contributor II
Desperately asking again....
I have 360 images(Taken from a camera mounted on top of a car) and a Frame Table with ( X,Y,Z, SRS, Image, Name, Omega, Phi, Kappa) values. I created OIC and added the images using the frame table and filling the parameters as shown below.
When displaying the images in the oriented imagery viewer, the images are not showing the entire 360 view.
Things i tried:
1. I checked if the images correctly show 360 view with another viewer and YES they do. So there is no problem with the images. here is a screenshot of the same image in another viewer
2. I created Pipe separated string CameraOrientation field using the Orientation schema Type 2 and 3. but that did not fix the stitching problem.
             2|H_WKID|V_WKID|X|Y|Z|RA1|RA2|RA3
              3|H_WKID|V_WKID|X|Y|Z|RA1|RA2|RA3
3. I tested with different parameter values of the Camera Heading, Pitch and Roll and Nearest and Farthest distances Values. But these didn't fix it.
4. I created OIC for another data and location and the Stitching problem is still there.
Can someone please help me figure out how to fix this?
RandallRebello
Occasional Contributor II
HI
Can you share with me a sample image please. I can test it out and get back to you with a solution. You can send it to me as a private message.  Also send me the table you are using. Just a few records.
Secondly just to confirm you are working with the classic Oriented imagery catalog and not the integrated version.
Randall
HabtamneshGoite
New Contributor II
Thanks for  your response! I am using the add on Oriented Imagery Catalog not the integrated Oriented Imagery Dataset. OID Viewer does not even support 360 images at all. I can't share any sample image other than those screenshot above.
Here is the header of the frame table I used
when trying the PS string for Orientation, I used CamOri field instead of the individual Omega Phi Kappa fields.
RandallRebello
HI
Without seeing actual values I cannot do much.
I need to see what is happening. Send it to me as a private message on here. I can assure you it will not be seen by anyone else other than me.
Randall
HabtamneshGoite
New Contributor II
It looks like there is some kind of problem with ArcGIS pro Oriented Imagery Viewer! I just created an experience builder app with the same Oriented imagery catalog and the Viewer correctly displays the entire 360 degree view.
RandallRebello
Hi
Then can you check if you are using the latest version of the ArcGIS Pro addin?
Randall
