is it possible load both esri v10 and esri v100 sdk at the same time in the same appDomain?
598
04-30-2020 09:13 AM
MathieuLemay1
Both have the same dll hardcoded name Esri.ArcGISRuntime.dll
When i try only 1 of the 2 is loaded, even if i force Assembly.LoadFile, it is loaded in the appDomain but cannot use it got:
LOG: The same bind was seen before, and was failed with hr = 0x80131040
KimberlySaballett
I don't believe you can as even if you get both to load in your project, both dlls will contain similarly named assemblies that would overlap and cause other issues when attempting to reference one specifically.
