How to calculate/get 4 points (and angle) of a rectangle by two corners
3347
05-23-2023 01:36 PM
Labels (3)
SokoFromNZ
Hi guys,
I'm kinda lost with my problem after hours of reading and research so I hope you can help!
I have two points (red) on a map like this:
And I like to calculate the two other points and angle in degrees of the rectangle (blue arrows) for a given aspect ratio of the rectangle:
I do not need to draw them on a map, just calculation and just in 2D Cartesian mathematics.
I've looked through all the GeometryEngine methods and couldn't find anything I can do a rotation of a Polyline for example...
It may be possible to do it with Extend and Intersections (also mentioned here) once I can draw the green rectangle... but its kinda complicated.
Anyhow: How do I get/draw the four sides of this rectangle?
Also MultipointBuilder looks promising... but can it draw a rectangle?
Finally reading through geometry help and make-measurements didn't really help. Although it mentions AngularUnits it does not say how to determine an angle of a Polyline or Segment.
Thanks for your help!
Soko
PS: Am I overthinking this to much in a big way? Can I do the calculations with simple trigonometry instead of GeoemtryEngine methods?
JohannesLindner
MVP Alum
Probably. I don't know anything about the .Net SDK, but here is what you could do in pure Python (without  using the arcpy geometry methods):
import math
# some basic trigonometry functions
# points as coordinate tuples
# angles in radians
def distance(p1, p2):
    return math.sqrt(math.pow(p1[0] - p2[0], 2) + math.pow(p1[1] - p2[1], 2))
def angle(p1, p2):
    return math.atan2(p2[1] - p1[1], p2[0] - p1[0])
def point_from_angle_and_distance(p, a, d):
    return (p[0] + d * math.cos(a), p[1] + d * math.sin(a))
def get_rectangle(p1, p2, aspect):
    """ Outputs the vertices of the (a) rectangle defined by the two given corner points and the aspect ratio.
    p1, p2: Coordinate tuples of two points in a diagonal of the rectangle
    aspect: ratio of the two sites (<= 1)
    # get the center of the diagonal
    a_p1p2 = angle(p1, p2)
    d_p1p2 = distance(p1, p2)
    center = point_from_angle_and_distance(p1, a_p1p2, d_p1p2 / 2)
    # convert the aspect ratio to angle between the diagonals
    a_diag = math.pi - 2 * math.atan(aspect)
    # get the other two points
    p3 = point_from_angle_and_distance(center, a_p1p2 - a_diag, d_p1p2 / 2)
    p4 = point_from_angle_and_distance(center, a_p1p2 + math.pi - a_diag, d_p1p2 / 2)
    # reorder and return
    return [p1, p3, p2, p4]
Now let's give that method a spin... We will read from a Multipoint layer, convert the multipoints to coordinate tuples, calculate the resulting rectangle for multiple aspect ratios, convert those rectangles into arcpy.Polygons and write them into a polygon layer.
aspect_ratios = [0.01, 0.25, 0.5, 0.75, 1]
with arcpy.da.InsertCursor("TestPolygons", ["SHAPE@", "DoubleField1"]) as i_cursor:
    with arcpy.da.SearchCursor("TestMultipoints", ["SHAPE@"]) as s_cursor:
        for shp, in s_cursor:
            p1 = (shp.firstPoint.X, shp.firstPoint.Y)
            p2 = (shp.lastPoint.X, shp.lastPoint.Y)
            for aspect in aspect_ratios:
                rect_points = get_rectangle(p1, p2, aspect)
                vertices = [arcpy.Point(p[0], p[1]) for p in rect_points]
                poly = arcpy.Polygon(arcpy.Array(vertices), spatial_reference=arcpy.SpatialReference(25833))
                i_cursor.insertRow([poly, aspect])
 Result:
So yeah, you just need basic trigonometry for this.
Have a great day!
Johannes
JohannesLindner
MVP Alum
import math
# angles in radians
def angle(p1, p2):
 Result:
Have a great day!
Johannes
JohannesLindner
MVP Alum
PS: This problem has two solutions, depending on which diagonal the two point describe. If you change line 26 to take the arctan of 1/aspect, you get the second solution.
Left: solution 1 -> atan(aspect), Right: solution 2 -> atan(1/aspect)
Have a great day!
Johannes
SokoFromNZ
Hi Johannes,
and thanks for the great explanation and phyton code. I'll give it a try to port it to C#.
About the two solutions: The two points are always lower-left, upper-right. So solution 1 is the right one for me.
One thing though I'm worried about:
This pure trigonometry solution works for sure in a "standard" coordinate system. By "standard" I mean were X and Y distances/units are the same.
But longitude and latitute distances are not the same afaik. Apparently even one unit/degree is a different distance depending where you are on the globe.
Do you think this matters?
Soko
JohannesLindner
MVP Alum
Oh right. this calculation is for cartesian coordinate systems, as per your question.
I have only worked with projected coordinate systems until now, so I'm not really sure how this will play out in a geographical coordinate system. The error might be negligible over small distances, but for greater distances, it will probably become apparent.
Maybe you can get away with converting the points into a locally applicable projected coordinate system, do the calculation, and then project the resulting points into the geographic system.
Have a great day!
Johannes
