FeatureReduction.MaxScale hides individual graphic labels
1282
08-16-2024 06:14 AM
Labels (3)
LarsNess
Hi Esri and ArcGISRuntime enthusiasts!
We have a problem when using GraphicsOverlay.FeatureReduction.MaxScale. When this value is set, affected graphics seem to have their default LabelDefinition hidden when clustering is not active.
Given the sample below, can anyone spot an error in the code, or is there a known problem with this?
Thanks in advance for any help!
public GraphicsOverlay CreateGraphicsOverlay()
     var graphicsOverlay = new GraphicsOverlay
         IsVisible = true,
         Id = "points",
         Renderer = new SimpleRenderer(new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Square, Color.Blue, 16).ToMultilayerSymbol()),
         FeatureReduction = new ClusteringFeatureReduction(new SimpleRenderer
             Symbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Circle, Color.IndianRed, 16)
             //Label when clustering
             LabelDefinitions =
                 new LabelDefinition
                     labelExpression: new SimpleLabelExpression(simpleExpression: "[cluster_count] CONCAT \" Items\""),
                     textSymbol: new TextSymbol {Color = Color.Black, Size = 12}
                     Placement = LabelingPlacement.PointCenterCenter,
             MinSymbolSize = 50,
             //BUG! WHEN THIS IS SET, MANY LABELS ARE NOT VISIBLE
             MaxScale = 30_000,
         //Label for individual points
         LabelsEnabled = true,
         LabelDefinitions =
                     new LabelDefinition
                         labelExpression: new SimpleLabelExpression("[Name]"),
                             Size = 12,
                             FontWeight = FontWeight.Bold,
                             BackgroundColor = Color.White,
                             HaloColor = Color.White,
                             HaloWidth = 1,
                         Placement = LabelingPlacement.PointBelowCenter,
         RenderingMode = GraphicsRenderingMode.Dynamic,
     var random = new Random();
     for (var i = 0; i < 100; i++)
         const double OsloN = 59.95138;
         const double OsloS = 59.91070;
         const double OsloE = 10.80758;
         const double OsloW = 10.70544;
         var x = OsloW + random.NextDouble() * (OsloE - OsloW);
         var y = OsloS + random.NextDouble() * (OsloN - OsloS);
         var graphic = new Graphic(new MapPoint(x, y, SpatialReferences.Wgs84))
             IsVisible = true,
         graphic.Attributes["Name"] = $"Point {i}";
         graphicsOverlay.Graphics.Add(graphic);
     return graphicsOverlay;
PreetiMaske
Thanks for reporting the issue, I am able to reproduce the problem. I have logged an internal issue and will investigate this shortly.
Preeti
PreetiMaske
Preeti
LarsNess
Thanks for looking into this!
