Raster Calculator not able to open in model builder
1442
08-24-2025 05:37 PM
CanaanT
Hello,
I'm having some really frustrating issues with ArcGIS. I am unable to open (double-click and right click open) the Raster Calculator in Spatial Analyst Tools to edit the parameters. I thought it might be the window hiding but I am able to still move the tool within the model but I can't adjust any parameters or edit an expression within the model.
I am using ArcGIS Pro 3.5.0 and I've tried the same thing on a more current update as well. Really frustrating!
Thanks in advance,
DanPatterson
MVP Esteemed Contributor
try adding some data to the model first and see if you can connect it to the raster calculator (can't test right now, but it would make sense)
... sort of retired...
CanaanT
Unfortunately did not work. I loaded in the data first then added the tool and connected it. Still can't double-click or right click open.
DanPatterson
I can't tell from the image but is the spatial analyst extension licensed and available
Use extensions—ArcGIS Pro | Documentation
or is the tool locked?
CanaanT
I am still able to use the tool within Geoprocessing Pane, I just can't edit it within the model.
NaturalPremier
I had a similar problem. After a few hours of trying, I found that if I made a bunch of raster calculator objects I could add parameters sometimes (open the raster object in the model)  but it would never run properly.  My peers who had a similar problem said that deleting ArcGIS and Downloading the latest software version resolved the problem.
