Model builder exporting layers and repeating/Duplicating Name
560
11-17-2025 08:46 AM
MarkYoung2721
When I add an output from model builder to the map it is duplicating the layer name and I cannot see where the duplication is coming from. Seen a few posts about this and wondering if it is a bug? For example i want to select and export  features from a feature class called  Rivers but model builder puts it in a group called Model Builder and calls it RiversRivers
Thanks in advance for any help
Mark
DuncanHornby
MVP Notable Contributor
I do not like output from modelbuilder going into a group layer, it was something ESRI introduced a couple of versions ago in ArcPro. It breaks a load of model logic in my opinion. Rather than removing it ESRI have offered up an option to turn off this behaviour, first thing I do when updating/installing ArcPro!
Start ArcPro go to settings > Options > Modelbuilder and untick "Add output to model group layer".
That will stop layers ending up in a group layer and should deal with the naming issue.
