Manual input in model builder?
4578
10
08-22-2016 08:57 AM
HectorBorro1
Hi there!
I'm trying to build a very simple model in where I can type 4 digits and then show the layer with only the points that match the query.
The workflow would be something like this: (drawn in powerpoint)
then on a Layout, I need to change the test to reflect the store number in the title.
Any ideas on how to build it?
The rationale behind this is that I need to export Layout 150 times with twice as many layers...
Running an itereator is not feasible as I need to adjust the vivibility (extent and map scale) and export the layout after this is run...
HectorBorro1
aha! I'll give it a try. thanks.
Now half of my troubles are solved: Display only the features I need to see from a specific layer.
Now on to Toggling visibility for existing layers (which I will use in full, no editing or fooling around with those)
