Manual input in model builder?
4541
10
08-22-2016 08:57 AM
HectorBorro1
Hi there!
I'm trying to build a very simple model in where I can type 4 digits and then show the layer with only the points that match the query.
The workflow would be something like this: (drawn in powerpoint)
then on a Layout, I need to change the test to reflect the store number in the title.
Any ideas on how to build it?
The rationale behind this is that I need to export Layout 150 times with twice as many layers...
Running an itereator is not feasible as I need to adjust the vivibility (extent and map scale) and export the layout after this is run...
DanPatterson_Retired
the P would mark the spot as a model parameter
HectorBorro1
thanks Dan,
Ok That's a great first step, thanks!
so I managed to select the exact polygon I'm interested in using Select Layer By Attribute
How can I make it the only displayed polygon(s) according to my query? as if I were using a query...
Then the interesting part will be toggling another layer visibility based on its name...
HectorBorro1
PS. were you the Dan who joined the call earlier today?
haha yes... just got off-line I thought that name was familiar
HectorBorro1
well, nice to briefly meet you over the phone!  and thanks for all your help!
HectorBorro1
as Definition Query  is not a tool, I'm unable to add it to the model... any other ways to draw only selected features?
Short of making a separate layer (which could reside in-memory) I can't think of anything if definition query isn't available ...  in modelbuilder ... but I haven't had a look through the whole link yet.
HectorBorro1
Ok... I'll give it a try. How can I create a layer to reside in memory? (I understand this would create a temporary layer without creating a separate file?)
I don't want to die with another 300 layers...
In memory for PRO is in the link... effectively just a workspace that is temporary unless the results are saved.
