How do I take the accumulation value generated by a geometric network and add it to a field within a feature class?
1670
11-05-2018 09:53 AM
JacobRougeaux
I am working in Model Builder and would like to take the accumulation cost calculated by each iteration of a geometric network trace and add it to a feature class.  However, I don't know what tool or tools I need to run to accomplish this.  Ideally, I would like to get the accumulation cost value added to the GravityMain1 layer.  My model is included for reference.
DuncanHornby
MVP Notable Contributor
Read the Usage section of the help file for the Trace Geometric Network tool. You will see that output is a group layer which you need to extract from using the select tool. At that point you could extract out the values of interest.
DuncanHornby
JacobRougeaux
Thank you!  I wasn't sure how to get the data from the group layer but that solved it.
