Broken Model
1457
01-27-2017 01:42 PM
BrandonPowell1
I had a model that was built in ArcMap 10.4.1 and worked fine. This week I upgraded to ArcMap 10.5 and the model is now giving me an error "WARNING 000117: Warning empty output generated"
This error seems pretty generic to me, and I'm just wondering if there is something I'm missing in my upgrade to 10.5 that will easily fix my model?
DarrenWiens2
The good news is that it's a warning, not an error (i.e. the model ran to completion). The bad news is that it's up to you to troubleshoot why the output is empty even when everything ran properly (e.g. trying to intersect two layers that don't intersect will give you that warning). Can you track down which tool gives you the warning?
BrandonPowell1
Thanks Darren for your input. I was able to track down an issue with my input data and not the model.
