Legend question
3342
06-21-2016 08:40 AM
DEAF_PROBERT_68
Honored Contributor
Is there a way for me to display a label over the layer on the legend ? I am familiar with the legend and know how to use it.
I have a road layer here and I have roads  showed their road labels on the Layout but I am not sure HOW to insert the labels with the road for the legend ?  Do I need to create a picture and then insert it in the legend ?
Robert_LeClair
Esri Esteemed Contributor
Convert your legend to a graphic and then add graphic shapes and text over the graphic legend.  Not exactly the most elegant way to do it, but it will work.
DanPatterson_Retired
moved to Mapping
Robert_LeClair
DavidBarnes
There isn't an easy out of the box solution for this. As a workaround you could add a graphic or picture on top of the legend in the layout. The added graphic or picture won't be dynamic, so if the legend changes or is moved the graphic won't update with it.
DEAF_PROBERT_68
Honored Contributor
I use the Drawing toolbar and convert the labels to graphics to make this.
Not perfect or elegant way to do it but here it is
