Identify Tool - bad GUID #
3430
08-21-2012 01:50 PM
JohnWahren
Hello all,
I just upgraded to Arc 10.  I am in the process of getting my VB Visual Studio 2008 Express compatible with 10.  Everything seems to be working pretty good.  But I have this code which activates the Identify Tool and now it seems the CommandItem variable will not recongnize the GUID # for the Idnetify Tool.  It worked fine with Arc 9.3.1.
pcommandItem.Execute() is working for other commands, just not the Identfy Tool.
'Create a new IdentifyDialog and associate it
        'with the focus map and the map's display
        m_pIdentifyDialog = New IdentifyDialog
        m_pIdentifyDialogProps = m_pIdentifyDialog 'QI
        m_pIdentifyDialog.Map = m_pMxdoc.FocusMap
        m_pIdentifyDialog.Display = m_pActiveView.ScreenDisplay
        'Clear the dialog on each mouse click
        m_pIdentifyDialog.ClearLayers()
        m_pIdentifyDialog.Show()
        'change to Identify tool
        m_pCommandBars = App.Document.CommandBars
        m_pID = New UID
        m_pID.Value = "{B7FA188F-EBE3-11D0-87FE-080009EC732A}"   ' This GUID # does not function
        m_pCommandItem = m_pCommandBars.Find(m_pID)   ' remains set to nothing
        m_pCommandItem.Execute()   ' Error
Any insight would be greatly appriciated,
jw
PeterYurkosky1
Identify changed a bit at 10.0. Try {CF605583-AEA3-41D8-9464-DDD1905243D9} (esriControls.ControlsMapIdentifyTool).
PeterYurkosky1
JohnWahren
New GUID worked!
Where are the new GUID's documneted?
Thank you for your response!
jw
PeterYurkosky1
Just look up the ControlsMapIdentifyTool class in esriControls. I'm not sure how well-documented the GUID switch was.
