Model builder parameters
2348
07-25-2012 08:45 AM
CoyPotts1
Hello!
In the beginning of my model, I need for it to reproject a raster. I'm taking the raster from "NAD_1986_NSRS2007_Transvers_Mercator" to "WGS_1984_UTM_Zone_16N" using the geographic transformation "NAD_1983_NSRS2007_To_WGS_1984_1".
This process runs fine by itself, but when I place it into model builder and create a variable that is a model parameter, there is no drop down box to select the appropriate transformation. I am currently trying to create a stand alone variable that I can just attribute with the correct transformation and have placed into the reprojection tool's parameters. I can't figure out which type of variable to create it as, though. For example, later in the model I have a few other stand alone variables that are created as "Field" type and their attribute is input into the appropriate parameter field.
Update: I can make a variable of type "string" and type "any type" and they both show that they can connect to the geographic transformation field, but when I click to do so they don't.
Any help is greatly appreciated!
C. Potts
JohnGallo
I'm having the same problem.
looked into making a copy and then "Define Projection" but that does not seem to ever give the option of a transformation.  I wonder where in the computer the projection files are, and maybe pointint to that path using an "any variable"?
JohnGallo
looks like I got it for now.  I think it was what you were alluding to.
make a string variable. populate it with the exact transformation text. then link that directly to the project tool, rahter than pulling out transformtaion as a variable and doing in line variable substitution...
