Hiding points on a map based on a common key field attribute
783
03-01-2022 11:53 AM
JoseBarrios1
Does anyone know if there is a way to hide/mask a point feature service from another point based on an common key attribute?  I have an Exp builder - embed Survey123 app that capture data from a point service data from a webmap and the survey creates another point service on top with another color. The problem is that the user can still see the old point and submit the survey data again.  Since I don’t own the base point service that we are using to populate the Survey123 , we can not change/edit the symbology to reflect the changes. Any suggestions or ideas are much appreciated!
JB
