Different copies of package map files behave like one.
2222
07-31-2016 09:41 AM
FelipeBucaram1
I have created a package file. I want to modify a copy of that packaged file but preserve the original. If I open it directly and modify it, then both package files get modified, the original and the copy.
  • Also:
    • They both unpack with the same name to the same folder.
    • If I erase the folder that is automatically created then all changes are erased from all package files.
    • If I use the extract tool then a new .mxd file is created and the problem is solved. They both alter only their specific package file.
Why is ArcGIS behaving like this? I am curious because I am learning to use it.
Thanks!
DanPatterson_Retired
Package Map—Help | ArcGIS for Desktop
uses the *.mxd first and foremost, which means that if you want a different version, then you should give it a different name AND even if you don't change anything in the project and want to make a copy, there is nothing wrong with saving A.mxd as B.mxd  even though they are identical.  You could exploit this by using the following
original.mxd
backup_2016_07_31.mxd
backup_2016_08_01.mxd
etc
then create packages as you see fit from the mxds which may or may not reflect changes in input data and/or other project changes.
My rule, never overwrite an mxd (except in the most minor of cases), do incremental saves and one ultimate backup every day
FelipeBucaram1
Thank you Dan. That is very helpful!
